Reconditioned a dash bezel for my '95 CS convertible
Old Oct 21, 2018 | 10:08 AM
Human's Avatar
Forward into the Past
As I mentioned in another thread, I went to a junkyard a few days ago and harvested a few parts off of a '95 Cutlass Supreme coupe to go onto my '95 CS convertible. One of the pieces I picked up was the instrument panel bezel. I have an FM modulator that will allow me to play music from my phone or my iPod through the FM antenna of the car's radio but I need to mount a power switch for it, which entails drilling a 16mm hole. I'd rather not butcher up the original dash bezel, which is in pristine condition, so I wanted a second one for this project. The one at the yard was in good condition except for where somebody had glued on some sort of a clip, perhaps to hang their cell phone. The clip was easy enough to pull off, but it left an awful mess of crusty glue residue. Goo-Gone wouldn't touch it, so I decided to try acetone. Amazingly, Walmart doesn't sell acetone in the paint department. I had to get a little bottle of it in the cosmetics department, where it's sold as nail polish remover. Long story short, the acetone didn't remove the glue but it took the paint off that corner of the bezel. Who knew those things were painted? The paint is almost the same color as the plastic, except for a slight texture and the barest little hint of metallic flake. At that point, I just gave up and got out a detail sander and smoothed that corner up without much regard for appearance. I remembered I had a rattle can of black Rustoleum Universal Hammered Paint and Primer in One that I had used to repaint the power nozzle for an Electrolux vacuum cleaner last year. The nice part about this stuff is it's got a textured finish that hides a world of sins. After masking off the vents, I gave it a spritz and am very pleased with the results. The color is a spot on match for the original but the finish is a little glossier. It really shows up in direct sunlight but I think it'll be more subdued inside the car. I was briefly tempted to paint the whole thing but for once, overspray worked to my advantage as it created a natural fade from one into the other. I wish I had taken some 'before' pictures, but I was more interested in painting the thing, so there you have it.
You can see the shine on the outer edge, but compared to how it was, I'll take it!
For an off-the-shelf solution, I really can't complain. I was tempted to keep going and paint the whole thing, but with any project, the most important part is knowing when it's done.
Old Oct 21, 2018 | 07:57 PM
Human's Avatar
I've been thinking about where to mount the power button on this bezel and I've just had a crazy thought over the past few hours that maybe instead of drilling another hole in that dash bezel to mount the switch, I should just use the one for the cigarette lighter. I don't smoke and there's a second 12-volt outlet on the passenger side of the center console, so I could live without the lighter. Besides, it would be funny watching others try to start the car by pushing the button. The best part is it would be a reversible modification, so I could even use the original one but the hole is way bigger than I need, so I'm not sure how I would make that work. Oh well, gotta love a good challenge.
71 Cutlass
Jan 13, 2017 09:35 AM
ransomolds
May 15, 2014 04:15 AM
Rocketbrian
Jan 13, 2012 10:10 AM
Hairy Olds
Feb 27, 2010 12:49 PM
