Cam lobe seperation
Old Sep 17, 2018 | 03:54 PM
crank shaft's Avatar
Cam lobe seperation
Does anyone have any advice on motor mounts. I have a 1970 supreme with a 108 cam lobe seperation. I love the cam but the engine lobe so much it shakes the car. Anyone have any idea on how I can take this beast down?
Old Sep 17, 2018 | 05:04 PM
RandyS's Avatar
Increase the idle RPM a bit.
Old Sep 17, 2018 | 05:05 PM
Ill try that. Thanks
Old Sep 17, 2018 | 06:28 PM
bw1339's Avatar
Manifold vac advance could help too.
Old Sep 17, 2018 | 07:06 PM
How much should I push it? Set a 12 degrees now
Old Sep 18, 2018 | 09:06 AM
12º is good, just be sure to use a manifold vacuum source so that you have that full 12º at idle.
Old Sep 18, 2018 | 05:03 PM
The guy that did my Dyno tune told me not to run vacuum advance. I should ask him why. I know he had the distributer out and put it on the distributer machine.
Old Sep 18, 2018 | 11:19 PM
I'll take a whack at this one -- because he doesn't know how to set up the distributor to run properly with the vacuum advance intact? I'll go with my answer, but if you do ask him, be sure to also ask why the factory put it there in the first place.
Old Sep 19, 2018 | 02:56 AM
I'll call him and ask him that question. Thank yoo!
Old Sep 19, 2018 | 03:03 AM
I wonder if it's because that cam dosent produce much vacuum at idle.
marklt
Apr 23, 2015 06:11 PM
WoofWagon
Apr 30, 2012 01:08 PM
haack52
Nov 4, 2009 11:17 AM
Mike Hathaway
Mar 23, 2005 08:12 PM
