94,95 Oldsmobile convertible
Old Apr 22, 2018 | 07:56 AM
Canuck olds's Avatar
Looking at 94,95 Oldsmobile supreme convertible, anybody have opinion on the 3.1 or the 3.4 six , or those cars in general thanks.
Old Apr 22, 2018 | 11:05 AM
cherokeepeople's Avatar
3.1 is way easier to work on.
Old Apr 23, 2018 | 08:25 AM
Weezer's Avatar
Jeff
The 3.4 is a "run away, run away now" engine. This is mainly due to the service issues for the timing belts typically needing replacement every 75k miles, and having to pull the engine in order to do it.
Old Apr 23, 2018 | 11:15 AM
19684424speedconvertible's Avatar
I did timing belts in both my 93 and 94 cutlass with the 3.4 DOHC engines. It was NOT easy but I didn’t have to pull either engine out. 3.1 is easier to work in but the 3.4 definitely has more get up and go. If you are a good mechanic go with the 3.4, if not so much than the 3.1.
halfmoontrail
Mar 22, 2014 05:20 PM
halfmoontrail
Aug 31, 2013 09:05 PM
70SXchris
Feb 24, 2012 05:02 AM
70SXchris
Mar 25, 2011 09:31 PM
djsoldzparrts
May 22, 2008 12:53 AM
