Seized brake reservoir cap
Old Jan 14, 2018 | 10:38 AM
Lou's1966442's Avatar
Could someone give me some advice on freeing the master cylinder cap on my 1966 F85? Recently got the car. Sat for years. Folded over the cap lock/spring/tensioner...whatever it may be called.....and I can't get the cap itself to budge. Thank you for any and all responses!!!
Old Jan 14, 2018 | 10:46 AM
Just tap up lightly along the lower lip. The rubber gasket may have stuck to the MC body.
Old Jan 14, 2018 | 01:18 PM
classicmuscle442's Avatar
If it's that rusty just remove it from the car, will need to rebuild or replace anyway. Modify an old can opener to work lid loose, original lid will be hard to find.
Old Jan 14, 2018 | 04:18 PM
Thank you for your response! Cap isn't rusted...vehicle sat for many years. I successfully removed it. Reservoir was nearly empty. Upon my surprise...once topping off, the brakes pumped up nicely. Thanks again for your response!
Old Jan 14, 2018 | 06:25 PM
You probably need to bleed the system.
Old Jan 14, 2018 | 06:32 PM
Thank you for your response! Will do.
Octania
Feb 1, 2014 05:27 PM
Tvan
Aug 3, 2012 08:35 PM
Lady72nRob71
Brakes/Hydraulic Systems
16
Oct 3, 2011 07:34 PM
Mark71
Jun 26, 2011 06:01 PM
dingusboy
Sep 7, 2010 12:17 PM
