Cadillac load leveling compressor
Old Mar 10, 2009 | 05:20 PM
jensenracing77's Avatar
i have a NOS compressor for a 66 to 76 Cadillac. it is for the automatic load leveling option. part number 4992919. does anyone know where i could sell this or how much to even ask for it. i thought about e bay but i don't know Cadillacs well enough to post it correctly.
Old Mar 10, 2009 | 06:02 PM
bigoldscruiser's Avatar
2 '66 98's
How about showing a picture of it. I think it is the same for Olds and some other GM cars. I have seen a later model Chevy with the same animal as I have from a '66 Olds Lux sedan.
Old Mar 11, 2009 | 02:18 AM
Bluevista's Avatar
Registered
Is it a small, looks like a can with a diaphragm housing on the end? Need a pic. Is it a vacuum pump or compressor? It may be totally different but if it is the same as the other Caddy vac units those can be used for auxiliary power brake vacuum assist pumps if you put a pressure switch on it. Worth big bucks on evilbay as a brake assist pump if it's the right kind.
Old Mar 11, 2009 | 12:36 PM
this is a picture of the compressor. i have one of those vacuum pumps also NOS. i will get a picture of it also. i don't need these parts and would like to sell them.
Old Mar 11, 2009 | 01:23 PM
this vacuum pump turned out to be a vacuum powered compressor. also for load leaveling. anything you can tell me about them would be a great help.
Old Mar 12, 2009 | 06:49 PM
2 '66 98's
I have one like that small one in the last picture. If I remember right, I bought it from Sears and Sawbuck many moons ago. The original one for the Caddy is similar to the one from the Olds but the can is much shorter. The top portion looks virtually the same but the can for the Olds is about 12" long. They make good pressure to pump up air shocks but you need the control switch that mounts on the rear housing to make a working load leveling system.
e129745
Suspension & Handling
Apr 17, 2014 03:02 AM
DeadBang1968
Jan 19, 2011 06:35 AM
Diego
Nov 8, 2009 07:49 AM
mp71conv
Dec 17, 2008 11:03 PM
yotee1642
Jun 16, 2008 01:11 PM
