Choke
Choke
I have searched past threads but they are a couple years old. Anyone have an opinion on what Brand Electric Choke conversion kit would be best for my 1976 Cutlass 350? I think Jet has a kit. Others? They seem to be under $50. so it's reasonable, in my opinion. I already have the wire there for my Holley.
Tom
Tom
Tom
Tom
I have been running one of those for years, from a chebby carb. I just bent a regular connector to fit. You just have to remove the gasket and maybe put a dab of sealant in the hole, in the choke coil housing.
If you already have a flat wire connector, I have the electric element. If you have L shape, I have those also.
Just remove the gasket so the element can ground to the housing and block the hot air vacuum source.
http://www.quadrajetpower.com/online...ory%3D20893457
