Panel replacement ??
Anybody ever replace the panel directly behind the rear window on a 1970 holiday coupe, what is it called and was it a big job to do ?? thanks Greg
I did that on my '70 Supreme back in the 80s due to rust under the vinyl top. I welded in an entire section from a donor car. Removed the rear glass, cut out the entire panel and the window channel, and welded the replacement panel in.
This is the same panel im talking about. Is it available after market ???IMG_0391.PNG
Simple search:
https://www.millsupply.com/68-cutlas...69.php?p=34682
Simple search:
Dont think that is it. I need one for a holiday coupe. That piece looks a little different Not sure tho
Research before you do any cutting
Look up from inside trunk for spot welds where that panel meets the quarter panels. There may be some overlap that you can reuse to spot weld the new panel to. Drill out the existing spot welds. You may not get the gutter part that goes across under the trunk lid ( weather strip for trunk mounts to it) with the new panel so may need to reuse the existing one. May be spot welds there too.
