Cruise control
Old Nov 22, 2016 | 05:12 AM
Pfiffle's Avatar
Cruise control
I have a 1976 Oldsmobile Cutlass S that has factory cruise. I will never use it. What should I be asking for it on Ebay? I know it wont be much but I have no Idea.
Tom
Old Nov 22, 2016 | 05:32 AM
damaged442's Avatar
IMO, if you figure it won't be worth much, why not just keep it with the car?
Old Nov 22, 2016 | 06:08 AM
stevengerard's Avatar
Post some pictures, there are a lot more parts to the set up than one would realize. Another member just posted a link to a great guide on these setups so that will show you all the parts you need to take off. Most likely it will work on many years, maybe even 71 - 78? Worth something to someone.
Old Nov 22, 2016 | 06:54 AM
crimsoncolby's Avatar
X2 on the number of parts you need to remove for it to be a complete setup for someone.
You've got the turn signal stalk w/wiring pigtail, lower dash panel rocker switch, brake pedal brkt with vacuum cut-off switch, wiring harness out to the Regulator, Regulator itself, Servo w/mtg brkt and throttle linkage, both Speedo cables (one from speedo to Regulator and from Regulator to Tranny) and, required vacuum hoses.
Old Nov 22, 2016 | 07:51 AM
CRUZN 66's Avatar
Olds Fever
JMO, But why remove it... It will cost you in time and possibly money for a minimal return... A significant item necessary is the turn signal level which operates the cruise... Do you already have another lever to replace the cruise lever which may entail taking the column apart... You will have to cap off and/or reconnect vacuum hoses as necessary etc. etc...
mruders
Feb 4, 2014 08:15 AM
bandit600
Jul 6, 2008 05:53 PM
ncwitte
Ninety-Eight
Apr 12, 2007 05:03 AM
Mr. King
Mar 28, 2007 06:26 AM
ztim
Dec 22, 2006 10:17 PM
