Can someone verify the spark wires?
Old August 17th, 2016, 08:18 PM
GHOSTOWLGRID's Avatar
Distributor 1 position?
I am seeing conflicting info online
can someone verify if this is correct? I see different number 1 positions online for the distributor.
This one:
http://ww2.justanswer.com/uploads/Vi...62238_olds.jpg
And this one:
http://www.performanceboats.com/attachment.php?attachmentid=57176&d=1255666294
I have an HEI cap with the coil built into it.
Will the number 1 always be in the proper place, or is it possible for any pin on the cap to become number 1?
GHOSTOWLGRID is offline
Old August 18th, 2016, 05:18 AM
m371961's Avatar
Any pin can be #1. It all depends on how the distributor is installed. If the engine is at TDC compression stroke on #1 cylinder, The dist. rotor can point to any pin when installed, making that pin #1.
m371961 is offline
Old August 18th, 2016, 06:13 AM
These are the 2 recommended #1 positions on the cap. The other issue is the placement of the vacuum advance canister so you have full range of adjustment for your timing.
oldcutlass is online now
Old August 18th, 2016, 06:51 AM
^^^THIS
People lose a lot of sleep over this, for no good reason. The No. 1 terminal on the cap is the one the rotor points to when the No. 1 cylinder is at TDC on the compression stroke. The diagrams all assume the distributor is installed in the factory orientation. If it has been moved at all, all bets are off.
joe_padavano is offline
Old August 18th, 2016, 10:32 AM
Ok.
So when I set the number 1 to compression top and I pull the top of the distributor to look, do I have to reset the timing on it?
Or is the top cover fixed and I can just put it back and not worry about messing up timing?
What I mean is, is the top a fixed position or variable?
Old August 18th, 2016, 10:36 AM
Originally Posted by GHOSTOWLGRID
Ok.
The distributor cap has a tab and only goes on one way.
Old August 18th, 2016, 12:50 PM
Found it.
Yah someone set the wrong pin as number 1.
I just left it because the timing is fine but at least now I know.
Old August 18th, 2016, 12:53 PM
How do you know the timing is fine?
Old August 18th, 2016, 12:58 PM
Found it.
If the timing is fine, then by definition it's not the wrong pin.
Old August 18th, 2016, 01:00 PM
m371961's Avatar
I would not word it as the wrong pin. Maybe because it is not as shown in a book, but happens often. Many times I have stabbed a distributor, made sure I had enough room to time it, then installed wires accordingly. Sometimes a diagram showing where #1 should be isn't available, sometimes I was just too lazy to look. Sometimes it was roadside. I have seen some caps marked with #1, but not in a long time.
m371961 is offline
Old August 18th, 2016, 02:13 PM
If you have a properly-sized set of spark plug wires, there are some clock positions of the distributor terminals that will not quite reach on some wires, if the wires are otherwise properly routed and the distributor can be rotated to a good position to achieve correct timing.
Other than this, there is no way to locate the distributor wires "wrong," so long as they are in the right order.
MDchanic is offline
Fummins
March 8th, 2016 03:26 PM
Hawghead
July 18th, 2014 12:51 PM
69442murph
Wheels and Tires
April 22nd, 2012 09:32 AM
72CUTTY
March 26th, 2012 08:46 PM
Wyze
March 27th, 2010 04:25 PM
Quick Reply: Can someone verify the spark wires?
