Wipers and washer pump both running
Old Jul 5, 2016 | 09:15 AM
The Bug Man's Avatar
71 442 BBO. Got out this weekend and had to use the wipers in a rain storm. Yes, I drive it in the rain. When I turned on the wipers the washer pump began pumping at the same time. Cycled it on an off several times but same result. Two speed switch located at left end of dash. Lift switch up to engage wipers, push in to engage washer. Any ideas ?? Thanks
Old Jul 5, 2016 | 09:50 AM
The washer pump is mechanically operated from the wiper motor. A solenoid in the wiper motor engages the link that operates the pump when the motor is turning. Either a short is causing this solenoid to be energized all the time or there is a mechanical failure in the motor that causes the pump linkage to be engaged all the time. Your Chassis Service Manual has full troubleshooting steps for the wiper motor.
You can determine if the problem is in the wiper motor or not by disconnecting the two-wire connector with the blue and yellow wires. If the pump continues to operate, it is a problem in the motor. If not, it is a short in the wiring or switch.
Old Jul 5, 2016 | 10:41 AM
Thanks Mr P. Started to just send that to you in a pm because I knew you would know ! Ill get the chassis manual out and look that over. It's a new wiper motor so Ill look at switch first.
Old Jul 5, 2016 | 10:43 AM
Don't bet on that. The brand new wiper motor I put in my wife's D88 turned out to have a bad park relay.
Old Jul 5, 2016 | 10:47 AM
Ok Thanks Ill go step by step per the manual
Old Jul 5, 2016 | 12:57 PM
Years ago I had the same issue with my wiper/washer. It was a two pronged plastic pawl(?) that engaged the cogged wheel on the wiper motor that works the washer pump. This piece has one long leg and one short leg, and one had bent over from age/use and no longer made contact as it was supposed to, so instead of the washer running for one revolution of the cogged wheel and stopping it just kept running.
The picture below shows the pawl that I am referring to. The overall wiper assembly may not be the same as yours but the washer pump part should be. That's a clutch head screw holding the pawl in. I had no idea what that thing was when I first saw it back in the 1980s.
need4speed
Apr 5, 2014 02:14 PM
Carl, uk
Mar 13, 2014 05:43 AM
markmets415
Jun 19, 2013 07:16 PM
1966 442
Apr 23, 2013 06:16 PM
69'442
Oct 15, 2011 06:45 AM
