You get what you pay for...
I use a high-quality BlueTooth headset for talking on the phone in my car.
The darned things cost $100 (I've bought a couple), but they let me talk on the phone in an open convertible with the other party being unaware that I am even in a moving car.
So a couple of days ago, the battery dies while I'm driving along, I plug the headset into the charger, and a surprising amount of smoke is released from it.
Like, probably ALL the smoke that had been in it.
Crap.
Finally today, I've got a chance to mess with it. I've got an old one that got stepped on and broke (small items, car floor, in the dark...), so I figure I can do a transplant.
First, though, before blaming the headset, I go out to the car, tape up the probes of my multimeter, and check the output voltage of the cigarette lighter charger I was using.
12.3V.
USB supply voltage is 5.0.
That'll do it.
I think that's the last time I buy one of those chargers that's next to the cash register at the hardware store.
Crap.
12.3V.
That'll do it.
Well, that's about the amount of smoke that came out of it -- and it's only about half an inch by two inches in size.
I checked out the two broken units I have - I could swap parts to make one good unit, but I can't find a soldering iron small enough to make the connections without wrecking the darned board. Grrrrrrrr... Damned cheapo charger...
I would never buy a 600.00 cell phone, and my camera is a sure shot I've had for close to 9 years. It ain't broke so I don't need a new one. I suppose I could get a new cell phone if I needed one, but my trusty ol Samsung is like the energizer bunny. One day the battery will crap out and I'll have to get a new phone because they don't make batteries that old.
Also, I don't step on things like my camera or phone
I've used a thick-ish paper clip in a pinch. Wrap it around the tip as many times as you can to capture maximum heat.
I just bought a car charger from the shell gas station that lasted 4 hours and now smells like a typical electronic that had been fried. Dam China, if I wanted fried Chinese goods I should a went to the corner Chinese food stop.
Once I had an el Chinko charger fry my phone and once I even had a cell phone explode that was not in use for a whole year, just exploded in my closest like that.
Was PO'd that the headset went POOF (with wisp of smoke) when I plugged it in, then checked the output of the 5.0V USB cigarette lighter charger - 13.4V, just like the rest of the car.
I should have sent the charger and the headset with a thank you note to Chairman Mao.
Hey Eric, since this thread is resurrected I wanted to mention that at work I often have need to solder a 42 gauge wire to a 10 mil wide trace on a circuit board. I started off using a sewing needle wrapped onto the end of a large soldering iron tip using 30 gauge bus wire, then I located a soldering iron with a 10 mil diameter tip. That made life a lot easier.
Ha. I forgot all about that part of the thread.
Yes, I did use a wire wrapped around the soldering iron tip, and yes, it did work for a while.
Then it didn't.
I'll buy another one when I get the chance, but for now, I've got a rental car with bluetooth, that a job is paying for, so I've just left it.
Then it didn't.
So, since the thread is current (bah!), a question. Did the USB charger ever work at all, or was the first use? If it did work for a while, I'm guessing the transformer melted and fused solid? If it never worked, maybe it was just a straight wire connection (yikes).
FWIW I bought a cheap Kenwood through Crutchfield that has Blue Tooth and an external mic for about $150. It sounds great and I can use the phone in my 40 year old convertible and I can actually hear it and the other person can hear me.
Worked fine for a couple of years, including about 3 days before, then POOF!
Instead of failure mode being an open circuit, failure mode was a dead short from the +12V input to the +5V output.
Quality design.
Quality design.
Go to Radio Shack or somewhere similar and get one with surge protection incorporated, or run it through a surge protector. I always do that when fitting 12 volt equipment to 24 volt systems, like a radio into a truck for example.
It will cost more then $4 but less than good blue tooth headphones.
Roger.
Roger.
