Would you look at this piece of garbage!
Old Jun 4, 2017 | 11:09 AM
DarrylJ's Avatar
Here are a few pics of my new Spectra premium heater core for my 71 Cutlass Supreme. It came from Pep Boys on their ebay store. Looks like it's going back!
Old Jun 4, 2017 | 11:18 AM
tru-blue 442's Avatar
Old School Olds
Bendy looking. Surely someone makes them in copper.
Old Jun 4, 2017 | 11:20 AM
marxjunk's Avatar
is it shipping damage?...cant blame them for that..stuff happens..
but i hear ya..its a bad feeling when ya need it and it shows up like that..
"bendy looking"..imma borrow that for awhile..lol
Old Jun 4, 2017 | 12:08 PM
If you find a source, be sure to let me know. I tried to get one a couple of years ago and all that I found were aluminum ones that weren't built correctly. I ended up buying a good condition used copper/brass one from a local Olds Club member.
https://classicoldsmobile.com/forums...-absolite.html
May 6th, 2015, 01:02 PM
The problem with the aluminum heater cores is quality control. I bought two different ones earlier this year and both had the same issue: the tubes were not angled correctly so it looked as if they would not fit through the firewall, the 3/4" fitting was at the wrong angle so it would be nearly impossible to get the hose on, and the ends of the tubes were too close together to get the hoses on (and actually touching each other on one of the cores).
The catalog description for the heater cores in question said "copper/brass construction" but when they arrived they were aluminum. I called the tech line and was told they just recently moved manufacturing to China and switched to aluminum construction, yet there was a label on the box showing the core was manufactured in 2013 and it was clearly marked "Made in China".
Old Jun 4, 2017 | 01:14 PM
That sucks. I got lucky when I went to OReileys for mine a while back, they got one from the warehouse here in N Texas. It had an inch of dust on the box but it was a copper and brass one.
Old Jun 4, 2017 | 01:18 PM
CRUZN 66's Avatar
Olds Fever
Was it actually packaged that way??? Or was it shipping damage... Shipping damage I can sometimes tolerate... But to package that from a quality control stand point doesn't say a lot about the manufacturer/supplier... Doesn't help the retailer's reputation either...
Old Jun 4, 2017 | 02:27 PM
My first reaction was that it must be from their Salvador Dali collection.
Old Jun 4, 2017 | 03:02 PM
Kennybill's Avatar
Elephant sat on it.
Old Jun 4, 2017 | 05:18 PM
DarrylJ's Avatar
It was in a box then in the shipping box as well. The packaging was perfect. No quality control at all.
Old Jun 4, 2017 | 05:20 PM
DarrylJ's Avatar
That's hilarious! lol
Old Jun 4, 2017 | 08:48 PM
Have a look at this link from Ground Up Restorations (Chevelle application). I believe the cores are the same for BOPC. Their picture shows it to be a brass/copper construction but I'd check first to see if it will fit your car, and if it really is made the way you want it.
Old Jun 4, 2017 | 09:10 PM
svnt442's Avatar
Allan they do fit cross the makes. GM used that heater core for a number of years for multiple applications.
Old Jun 4, 2017 | 09:13 PM
svnt442's Avatar
I would be extremely shocked if someone was making new copper/brass anything any more. It's just not cost effective as the price of copper makes using it unrealistic when aluminum pieces are readily available and MUCH cheaper.
Old Jun 5, 2017 | 03:55 AM
Old School Olds
Thanks for the link Allan. Randy, I took a chance on one and will let you know
if it's good to go. On the order form I let them know "If this is NOT of brass/copper
construction, I don't want it."
Old Jun 5, 2017 | 07:15 AM
ELY442's Avatar
I bought my brass/copper type from The Parts Place. I use the Memorial Day 10% discount and it costs me $44.
Old Jun 5, 2017 | 10:54 AM
Talking
You're welcome,
Smart move on your part to add that to the order. I'm curious what you will get, but I'm hoping Randy is wrong about the construction. If it is brass/copper I might have to look ar one for my car.
Old Jun 5, 2017 | 12:58 PM
Good luck with that. The catalog description for the ones I purchased said "copper brass" and the pictures showed the same thing, but I received aluminum parts.
Old Jun 5, 2017 | 01:55 PM
Old School Olds
Thanks Kenneth. I hope I get as lucky as I did with the Pepboys radiator.
Old Jun 5, 2017 | 09:37 PM
svnt442's Avatar
I worked for a radiator company about 20 years ago and they made all of their own cores and tanks in house. That was before the meteoric rise in the cost of copper and they still had plenty of those offerings to choose from.
After copper went through the roof it just wasn't worth it to make more and what inventory was left was it. When it sold out everything went over to aluminum....like it or not.
Old Jun 5, 2017 | 10:28 PM
I don't really mind aluminum as long as it is made correctly and fits the application properly.
Old Jun 6, 2017 | 02:17 AM
midnightleadfoot's Avatar
ph_ckstick1
Doubt this...
For those that never worked in auto parts.. There is a huge issue.. and it is people returning damaged parts.. parts they damaged. either by trying to force the incorrect part into the wrong vehicle..
Or in this case using the box as a step stool.. either by the shop or the warehouse.. As that is what that one looks like happened..
Shops are bad at this.. and if the vendor doesn't check every return.. you get stuff sent out like this..
We had to check ever box as the running scam with one account was they order moog from us and the house brand from autozone and put the autozone part in the moog box and return it..
Old Jun 9, 2017 | 04:06 PM
Old School Olds
Thanks for the link Allan. Randy, I took a chance on one and will let you know if it's good to go. On the order form I let them know "If this is NOT of brass/copper construction, I don't want it."
Sweet. Thanks again Allan.
Old Jun 9, 2017 | 04:26 PM
Who is the manufacturer on that copper core?
Old Jun 9, 2017 | 04:36 PM
Old School Olds
TSM, made in Mexico.
Old Jun 9, 2017 | 07:47 PM
CRUZN 66's Avatar
Olds Fever
Originally Posted by midnightleadfoot
Doubt this...
Not sure why you would doubt the quality control issue since the original packaging showed no evidence of damage or "being used as a step stool"... Even if damaged and returned, someone should have verified exactly what was returned and the quality of the item before repackaging to resell to another customer... JMO, but this goes back to quality control either from the factory or the retailer...
Old Jun 10, 2017 | 05:14 AM
Old School Olds
Here's the web-sight for those interested.
http://www.thermalsolutionsmfg.com/
Old Jun 10, 2017 | 09:03 AM
Glad it worked out for you Adam. I've seen quite a few cross reference parts from Ground Up and their pricing is pretty decent.
jag1886
Mar 17, 2018 12:12 PM
a64olz
Nov 12, 2012 07:07 AM
1BAD68"S"
Nov 9, 2006 04:30 AM
EdsDelta
Nov 16, 2005 07:23 AM
