Wiring Help 1970 A Body
Hello!
I need some assistance on wiring. I have a 1970 W31 that was previously converted to an HEI. I'm having it converted back to the correct points distributor and coil.
1) The car has a factory tach which currently works off of the HEI, what side of the coil +/- will the tach wire hook up to?
2) The coil bracket has a small radio noise condenser mounted to it where does that wire connect to? The coil +/-
I've checked the wiring diagrams that I could locate and I'm unable to get a clear answer. Thanks for any assistance!
Hello!
Tach is connected to the coil- terminal.
Condenser is connected to the coil+ terminal
If the harness is all hacked up it might be a good time to get a new harness under the hood. It's a good investment and well worth the money.
