Wire Wheels, to do or not to do
Old Oct 2, 2014 | 02:57 AM
lazy394's Avatar
I am toying with the idea of fitting 15 inch wire wheels and am seeking guidance from the knowledgeable masses on CO
I need to move to 15" wheels to restore the rolling diameter of the original tyres. ( 9.50 x 14 )
The new 14" radials I have fitted are as big as I can find and are 200mm (8 inches) shorter in the rolling diameter, causing untold grief.
Scott
Old Oct 2, 2014 | 05:58 AM
brown7373's Avatar
I had Kelsey Hayes wire wheels (14 inch) on a 1964 Thunderbird Convertible. They looked great on that car when they were clean and sparkling, but that was the problem. They were a bitch to keep clean. And that was on a trailered show car.
Old Oct 2, 2014 | 08:26 AM
I'm not a fan of wire wheels because as mentioned a bitch to clean. They also have a tendency of being hard to balance.
Old Oct 3, 2014 | 12:35 AM
lazy394's Avatar
They were on my shopping list back when I owned a 64 Tbird as well!
Cleaning and balancing seem to be common issues
Old Oct 3, 2014 | 02:11 AM
lazy394's Avatar
my old 64
Old Oct 4, 2014 | 08:21 PM
5998DownUnder's Avatar
Hi Scott,
http://www.antiquetyres.com.au
might help.
Old Oct 4, 2014 | 08:24 PM
They have 215/70/14 (Just checked my tyres-they are 215/75/14). They may have other tyres in stock.
They have wire wheels also.
Old Oct 5, 2014 | 05:36 PM
lazy394's Avatar
Originally Posted by 5998DownUnder
Hi Scott,
might help.
Cheers for that John !!
I will give them a buzz.
Old Oct 15, 2014 | 06:21 AM
Hi Scott,
How did you go, did you find the wheels you were looking for?
Old Oct 15, 2014 | 04:17 PM
Tedd Thompson's Avatar
I would think 215-70 -14's would still be on the small side. I also thought about chrome wire wheels, I think they look bitchin but then the bitch comes home you gotta clean each and every spoke. I re thought my desires and stuck to stock....Tedd
Old Oct 15, 2014 | 04:38 PM
These are what came with the car when I purchased.
I'll do some research and see what they came out from factory with and consider them for next time.
I may even go a bigger profile as I agree they do look a little like cheese cutters on the big old girl.
Old Oct 15, 2014 | 11:14 PM
lazy394's Avatar
Hi Scott,
Looks like ive found a set of 15' 72 spoke wires , putting on 225 775 15 returns the rolling diameter to within 10mm of the stock 9.50 x 14's
Old Oct 16, 2014 | 04:30 AM
73aussie455's Avatar
Acceleratii maxim rapidus
Nice. The're not hard to clean, just time consuming..
I use a thick bit of lambswool, gets around behind the spokes. Spray them after with a light mist of RP7, WD40 or Lanoline etc, doesn't harm the chrome, keeps road grime from sticking (easier to clean) and prevents rust. Chrome quality makes a big difference to how they will look in 10yrs..
My Delta rolls on 20" 200 spoke rims, 245 35 20 tyres. They're a bit smaller than stock, like dropping in a lower ratio rear end.
Old Oct 18, 2014 | 04:47 PM
lazy394's Avatar
are they Knock on wires?
Old Oct 19, 2014 | 02:15 AM
rustyroger's Avatar
'87 Delta 88 Royale
Properly polished wire wheels are hard to beat for looks imo.
But they are heavier than standard wheels, which adversely affects handling and ride quality, not enough to make it a no-no for cruising though.
As has been mentioned balancing is tricky, and you should fit tube type tyres as you will need tubes. Fixing loose spokes might need expert attention as well.
But it's your car and your choice, if you don't mind the downside and want great looking wheels, enjoy!.
Roger.
Old Oct 20, 2014 | 01:32 AM
Yep they're knockons Lazy. Adapter boss bolts up to the existing stud pattern, there are extra holes for many different patterns/makes. Teeth on the inside of the wheel engage with teeth on the boss. The spin on nut holds it all together, L/H and R/H thread for each sides of the car, so they dont unwind.
Although they look cool, I doubt the teeth/boss mounting idea would be able to handle too much 455ci torque, so no circle work for these, just sweet cruisin'..
Old Oct 20, 2014 | 02:00 AM
lazy394's Avatar
They do look awesome! I don't have your excess hp problem though
superstingray77
Jun 27, 2011 06:13 AM
Joel
Apr 12, 2011 02:58 AM
68cutlassdriver
Mar 6, 2011 11:53 AM
WTony
Jan 15, 2011 07:53 PM
mjc79
Nov 21, 2008 05:58 AM
