Winter “dry dock” upgrade plans?
Anybody have any big plans for their Olds this winter? My goal is to find that damn annoying creaking/squeaking noise behind the dashboard, repainting the dash while it’s out, replace the stereo with something Bluetooth compatible, and maybe recover the frt seats.
R&R both front & rear CA bushings, either box the rear CA's myself or purchase new, R&R front & rear coil springs, R&R rear fuel lines, install (new) rear sway bar & R&R front windshield rubber post seals (convertible).
Matt,
I had a dash squeak last year that turned out to be the cowl cover between the fenders and did not require dash disassembly. I can't remember the part name but it's the cover that snugs up against the bottom of the windshield covering the heater/ac vent screen.
My squeak sounded like it was coming from the inside, but it was actually minor metal on metal movement of the cowl on either the fenders or against the top of the firewall. Insulating the cowl on the ends and greasing it all over the place eventually took care of it.
Hope I can save you a "pull the dash" event.
Cheers
Chris
Cheers
Chris
Matt,
Cheers
Chris
Cheers
Chris
interesting, maybe I’ll go for a drive and make a video. It sure sounds like it’s coming from the dash, behind the radio
Pulling the 260 out of the 88 Cutlass, fixing the A/C and actually have it come through the vents instead of defrost and floor. Then pull the 350 from the 70S to go in the 88, fix the one bad lifter, put on the Performer intake, 1" open carb spacer and convert back to hot air choke which may require a custom tube to the carb with the spacer. Also a 5000 rpm Governor, bigger boost valves, TV line bias and the 2300 stall put back in the 2004R. Of course the secondary air door will be set as loose as possible. It should mean 20 mpg and burnout fun. I also plan on buying a Halo and longer studs to finally send my 403 block to the machine shop this winter for the 70S.
My old girl finally needed an overhaul for her 50th birthday (my cutlass that is). She is in pieces now and the goal is to fix the metal, paint and received a new power plant/suspension/brakes over the winter/spring (offer i could not refuse). Hopefully ready for the memorial day parade.
Ed
Ed
Had a number of things I was contemplating. Pulling motor and putting in lower compression pistons, changing gear ratio.. But we have our 1st kiddo coming in December this year. So nothing planed for foreseeable future on minor changes and such. Will see if I event get it out next year...
Where to start?
New brake lines, master, rotors and calipers, rear brake upgrade
New fuel lines
New gas tank,
Install new motor
Shouldnt take that long, maybe 8 or 9 months, if Im lucky. All these parts are already in my garage. Just need someone like Garage Squad to help..
New fuel lines
New gas tank,
Install new motor
I'll be putting mine in storage this upcoming week. Dropping the top an cruising in 40 degree weather isn't that much fun.
That being said, I have already started collecting parts for the few things that need doing this winter. I have new door panels for the front and back to go over and make sure all of the holes line up the way that they should. And I will also be recovering the rear arm rests.
Not too much. I spent the last 6 years getting her to this point and I'm glad to be finally down to the "little" nit picky kind of things.
I have a bunch of things planned for both my 70 W31 and my 72W30. I want to install the resleeved (stainless) EB and BE
master cylinders. Both have the correct date codes, are painted and ready to go.
I also have a set of XT rims I want to get dipped, primered and painted for a set of dog dish on the W31. My car never came with them (originally SS1’s as per the build sheet) but I love that look and why not.
I have a lot planned, the question is how much time will I have to progress the work? On the up side, retiring from my 9-5 first week of March and although I'm ramping up a screen printing/etc business I should have more free time to spend on the projects.
If all goes well...I'll be swapping interiors between two '70 Cutlasses (black bucket seat/console interior going into the keeper car), rear ends (limited slip with boxed arms into the keeper) and a few other pieces. The project still needs the engine bay cleaned/painted/detailed, the 455 opened up and inspected before clean/paint/install. New master cylinder, brake inspection, etc.
And there are a bunch of parts to replace/upgrade on my '71 as well.
While I would love to get the '70 on the road in 2020, I'm not optimistic so that '71 needs some lovin' too.
71murder
Suspension & Handling
23
Aug 27, 2021 01:31 PM
tmaleck
Drivetrain/Differentials
Oct 12, 2013 07:58 AM
