Wheels and tires
Wheels and tires
Anyone have a problem with this setup for my 72 Cutlass s before I hit the order button. Please don't try and sell me rims and tires I'm really just checking on the sizing making sure there a good fit. I do like the old school Crager and also wider tire and height in the back. Just a personal preference. Just double checking to big ? Too wide ? Wrong bolt pattern? Wrong offset, a little green when it comes to wheels and tires. Thx
Trying to paste my invoice here will try again
Couldn't cut and paste
Jegs number for front 260-61715 back 260-61815
Front tires TA radial P235/60R15
Back tire TA radial P275/60SR15
Wheel front SS Crager 15X7 bolt circle 5 X 4.5 rear spacing 4 1/8 offset 3mm
Wheel back ss Crager 15X8 same bolt circle rear spacing 4.25 offset -6mm
I hope that bolt spacing is a typo. All RWD Cutlii from 1964-1988 have a 5 x 4.75" bolt circle. I'd also be a little cautious of the -6mm offset on the rears. That will push the tires closer to the fender lip.
I haven't ordered them yet so everything can be fixed. These were the sizes I was given by a Jegs rep as he was talking with another guy. I want as deep a rim in the back as comfortably possible not looking to push the tire out. So the offset was misunderstood. The bolt circle will also get corrected. What is your recommendation for the old school look in looking for. I like wider and higher in the back with a deep rim which I guess would push the tire in not out then match the look in the front. Thx
That's exactly the problem. The "deep dish" look from the 1960s had lots of negative offset, which pushed the centerline of the rim and tire far outboard. That's why we all had air shocks and dangerous shackles.
I'd like to sit higher in the back, yours is even and looks really good but I like that aggressive looking junk in the trunk look not over done, but tastefully aggressive look. So would a 15x9 wheel and P275 back with a 15X7 P235 in front work or look ridiculous. I'm not looking for attention I have just the opposite personality, I don't do burnouts at car shows that look is just a preference. Old school cool like when I'm wearing my Winger shirt.
Fyi
Many guy run 235 60 15s up front and 275 60 15s out back. The 2" tire height difference crests the rake you are wanting. 275 60 15s look best on an 8" wide wheel.
I'm looking at 295/50s on 15x10's with 5" backspacing for the rear of my '71.
I'd go with factory backspacing, and let the tires hang out, but I don't know how that look would work with a convertible....
Using a 4x4 and a couple of jacks, I found I need to lift the rear just about 2" to obtain the raked stance I want and tire clearance I need.
I have caught some flack, mostly from the 'performance/pro-touring' guys in town, about the way I want it to look.
Hell, if I had a hard top, I'd have side pipes too. (Metallica shirt.... LOL)
I just don't know if I could pull that look off too with my convertible.
to the best of my knowledge Cragar SS are still Unilug in 14" & 15", 5x4.5/4.75/5. Confirm this but you should be OK with that. Make sure you get the right lug nuts.
The Crager ss is unilug comes 4 3/4 so I'm good there so I'm leaning toward the Crager ss 15 X 8 rear maybe 15 X 9 with the P275/60/RS15 (not sure what the s is) and Crager ss 15 X 7 and P235/60R15 tires
Offset and backspace no idea all I know is I'd like a deep dish in the back which I guess is accomplished with the 15 X 8 wheel any reason I can't do 15 X 9
Sorry I never had Winger shirt. Think I got that from Family Guy or Bevis & Butthead. Had a Jeff Beck shirt, several Stones, Zeppelin, Areosmith, they were all those big iron on decals from Sound Odessey that would stick to your chest. I'm and old Funk music guy myself love those horns. Might be a cool thread though back in the day iron on shirts. Watch the motor heads and metal heads chime in. What the heck I'm layed up id like to see some of those posts.
15x9 for the rear backspacing 5" you can even go 15x10 with 5.5" backspacing.
I was thinking of these wheels, I was hoping to strip the gold paint off to make it look more like the vintage dazzlers with gold only on the inside of the spokes
Dazzler Wheel
Size: 15" x 8"
Bolt Pattern: 5 x 4.75"
Offset: -12mm
Backspacing: 4.02"
Gold w/Aluminum Face
Just my .02
Doc do you have stock springs on that? I like the look, and you have no rubbing issues with the 255's? I had 295/60's squeezed on to stock rims LOL... but I had to use air shocks, gone far away from that idea now.
Dazzler Wheel
Size: 15" x 8"
Offset: -12mm
Backspacing: 4.02"
Dazzler Wheel
Size: 15" x 8"
Offset: -12mm
Backspacing: 4.02"
oldsguybry
Wheels and Tires
19
February 16th, 2013 10:14 PM
