wheel lip mldgs
"These molding fit 1970-71 Cutlass, Cutlass-S, and 442, 1972 All models including wagons. 1970-71 Supreme applications will have to be cut to fit"
I know the fronts are all the same, not sure about a difference between a Cutlass-S and the other models. The GM catalog shows a different number for the 70-72 Vista and wagon rear moldings than the non-wagons.
The only way to really find out for sure with stuff like that is to try it, they always look like they'll fit until then.
The Supreme is different because the Supreme uses a heavy die cast trim piece on the side of the car that's a few inches up from the bottom of the wheel opening. The wheel opening trim stops at the die cast piece instead of going all the way to the bottom of the opening, which is why the Fusicks catalog notes that their repro trim needs to be cut for the Supreme. It only involves shortening the ends by a couple of inches.
If your car didn't come with the wide side moldings you don't cut the wheel opening moldings off.
Unless you really want to for some strange reason Sandy, whatever floats your boat.
The mouldings on the Vista are wrong...they should be the same as the Supreme... I just looked at the '70 dealer album (pg 47) and the illustration for the two seat (4855) Vista has short mouldings and the three seat Vista (4865) has long mouldings ???
Last edited by Yellowstatue; August 17th, 2010 at 03:21 AM. Reason: Intense observation...
I was wondering about that. The 68 VC that I owned back when the dinosaurs roamed used wheel opening trim that was the same as that on the 68 Supreme. Of course those are different from the 70-72 cars, but the VC became sort of a "Supreme" station wagon, using similar upholstery, for example.
Mine's a two seat '71 and it has the long mouldings factory, the car was never touched.
The Fisher manual molding clip I.D. illustration shows the rears ending short, also shows a molding where there isn't one, rocker moulding ends short, quarter panel molding is short?
The assembly manual just shows long ones.
Have to find somebody with a period GM parts catalog and see if they list two different ones for the '70 wagons. I can't see how they would be any different than the later models?, especially to distinguish between two and three seaters?, but who knows??
Is this an illustration or a photograph?
They may have thought of it and it got to the art department but never into production.
I've never seen a 70-72 with short mouldings or have even heard of them but anything's possible. I searched forever for mine and only came across long ones.
I love a good mystery.
I'll ask around at the Olds show and swap meet this Sunday.
The part numbers are probably the same if they just cut longer ones off so that point of mine is moot.
69442C
January 10th, 2011 04:43 PM
