What are these parts from my 75 H/O??? pics attached
Can someone tell me what these parts are and where they belong, i think they belong with my front bumper/reinforcement but i can figure it out. Anyone out there know?
75 hurst olds
Thanks for you help
Mike g
75 hurst olds
Thanks for you help
Mike g
The silver metal bracket is a 73-77 arm rest base that mounts on the door before you mount the door panel. It will fit either side, there should be holes in the door panel waxpaper moisture barrier that the lower legs fit through into slots in the inner door metal. There are two slotted holes in the top of the part that the screws for the rubber arm rest pad, which is attached to the lower door panel, thread in to. I'm not sure on the other part, it does not look like the front license plate bracket on my 76 442 but the 75 part would be different. Is there a part number on the black piece?
Thanks guys for the help I appreciate it! I thought the black piece was a license bracket holder but cant figure out mounting. I will check part # to be sure and post part number.
Thanks again!
Mike disco bay, ca
Thanks again!
Mike disco bay, ca
oldzy
Dec 19, 2011 06:43 AM
