What is this part?
Old May 13, 2022 | 03:48 PM
joshduty's Avatar
What is this part?
Does anyone know what this part is? Its of a 1970 Cutlass with a 4 barrel 350. I cannot for the life of me figure it out. Is it some kind of air flow sensor?
Thanks for the help!
Old May 13, 2022 | 03:58 PM
VC455's Avatar
Barely Registered
That is an electrically-controlled vacuum solenoid that opens/closes depending on the current gear in the transmission.
The vacuum being controlled goes to the distributor vacuum advance. The purpose is to eliminate vacuum advance at idle and low speed (for emission control).
Refer to page 6C-18 in your 1970 Chassis Service Manual.
scrappie's Avatar
I'm gonna guess TCS (transmission controlled spark) switch.
Old May 13, 2022 | 06:28 PM
rocketraider's Avatar
Oldsdruid
TCS solenoid/switch as Scrappie said. Gary explained its function.
It alters vacuum signal to distributor vacuum advance depending on 1) engine temperature and 2) what gear the transmission is in. It shuts off vac advance unless the transmission is in high gear.
Most people disconnect and bypass it unless they're going for a high-point restoration.
Last edited by rocketraider; May 13, 2022 at 08:23 PM. Reason: Where did this thing get "eight-point restoration" from 🤨
Old May 13, 2022 | 09:16 PM
dragline's Avatar
Excellent picture of original hose/wiring routing. You can get that TCS switch new if yours needs to be replaced.
https://www.ebay.com/itm/27142874315...4aAtQjEALw_wcB
Old May 14, 2022 | 04:24 AM
VC455's Avatar
Barely Registered
Dean's right.
And consider that there is one condition where you might want to keep it...
It retards the timing at idle, which puts an artificial load on the engine. This results in less hydrocarbon emission (reduces stink of the exhaust). If that matters to you, follow the factory tune-up instructions.
Old May 14, 2022 | 08:57 AM
Apparently folks have done that since these cars were new. My Dad bought a 1970 Supreme 350-4bbl in 1977 from the original owner and that switch was not present even way back then.
Old Jun 17, 2022 | 01:58 PM
joshduty's Avatar
Thanks for the link... I think I may order another since it appears there are pieces that are broken on it.
PatL
Mar 29, 2022 11:52 AM
dalilama
Apr 1, 2016 07:32 PM
Skitch72
Oct 17, 2013 06:46 AM
bonnevillegreg
Apr 15, 2012 01:38 PM
sworthy555
Feb 26, 2009 06:13 AM
