what the H%** is this
It's in the spot where the cruise control transducer would go, it doesn't look like an original one but I'm not sure. Maybe it's part of an aftermarket type cruise system??
There is a vac line going to the brake booster line, could it be an electric vacuum pump for the brakes?? The engine have a high duration cam?
Otherwise...beats me what it is.
Somebody here will know for sure...or not.
Looks like this thing is feeding right into the brake booster vac line. It could be an electric vac pump. If this car has a lot of cam in it, it may not have produced enough vac at idle for them to work well. Just a thought from how it is plumbed in.
If it is is for cruise control the part on the fender that controls everything is called the transducer, also called the regulator assembly on some models.
The servo is the vacuum bellows mounted on the engine that works the carb linkage and is usually connected to the the transducer with a vacuum line.
I have about 4 transducers if yours craps out. BTW, I was asking around to see if anyone would repro that sticker but can't find anyone who'll do it price effectively up here. I have one that is NOS (74 I think) that is like a gold/bronze tinge, the other NOS one is blue like this. The others are really faded out.
I haven't taken any of the 'used' ones apart or tried them out yet.
Ironically, the one withthe nasty outside has the best label (the one you have posted (which is the exact one!))
I need to try to combine the two and see what I get.
Sounds good, the only thing you have to watch out for is the lateral bioscopic modulating valve on the lower part of the unit. If you don't put the coilover bimetal rotational variation detector properly onto the endoscopic vane, the planetary drive on the main shaft will not interact well with the command vacuum release and engage positions. This will cause fluctuations in speed and failure of electrical engagement pulse from the cruise stalk itself. One impropely installed endoscopic vane resulted in a severe crash. When NHTSA investigated, they determined the brake disengage pulse was diametrically interpreted by the archimedic locking thrust washer as a direct command to increase vacuum draw to the servo and throttle linkages. Got that?
