What does this wheel fit?
Old Jun 12, 2010 | 09:23 AM
davbell22602's Avatar
Its a 15in x 5 lug. Here's some numbers I found the rim 9214,c6d,8jkx15x35.
Old Jun 12, 2010 | 09:52 AM
rocketraider's Avatar
Oldsdruid
Buick had something very similar to that for early 80s Rivieras but that wheel doesn't appear to have enough offset for a FWD application, or a large enough bolt circle for a Buick. I think the Buick wheel was also chromed around the lug nut area.
The Pirelli Cinturato makes me wonder if it might be for a European car. Jaguar had a similarly styled chrome wheel, as did several Italian makes. Those hubcap mounting pins are unfamiliar.
In other words, I don't know.
Old Jun 12, 2010 | 10:21 AM
OK, The lug spacing 4.5 inches.
Old Jun 12, 2010 | 11:44 AM
gearheads78's Avatar
car guy
my money is on Jaguar
Old Jun 13, 2010 | 08:10 AM
I think I narrowed it down to a 70's XJ series jaguar.
Old Jun 13, 2010 | 10:35 AM
Jaguar XJ6 and XJ12 cars used the 5 x 4.75" bolt circle. If you are getting 4.5" by measuring between two bolt holes, that is NOT the way to measure the diameter of the bolt circle on a five hole wheel. If it really is 5 x 4.5", it's not a Jag wheel.
Old Jun 13, 2010 | 10:47 AM
I measured by outside of the first hole to the middle of the 3rd hole. I got a 4.5/114.3. Don't forget the XJ series came in 3 different series. Series 1, Series 2, and Series 3. I was told it fits a Series 1.
Old Jun 13, 2010 | 11:04 AM
And yet, all three series had the same bolt circle.
I used to own a 1971 Series I XJ6. It had the 5 x 4.75" bolt circle. See if this wheel bolts to a Cutlass.
Old Jun 13, 2010 | 12:40 PM
Ok, I remeasured and came up with 4.75. So 4.50 is incorrect, my mistake.
Old Jun 20, 2010 | 06:55 PM
What's this wheel fit?
14in x 6in wide, 5x100,
Old Jun 20, 2010 | 06:59 PM
agtw31's Avatar
that looks like a mid 80's T Type turbo 3.8 Riviera wheel
Old Jun 20, 2010 | 07:21 PM
cfhcar's Avatar
chevy celburty? can't remeber euro or not. they look the same but had different bolt pattern wiht
Old Jun 21, 2010 | 06:41 AM
What about a old Olds Cutless or Olds F85?
Old Jun 21, 2010 | 07:07 AM
J-(Chicago)'s Avatar
Seasoned beater pilot.
Those are Chebby Citation mags.
Old Jun 21, 2010 | 09:55 AM
Oldsdruid
With a 5x100mm BP, probably Celebrity or other X-car. That style was also pretty common on late-70s/early-80s Malibus, Novas and ElCaminos. I think I've seen some 82-84 bottom-feeder Camaros with them too.
Old Jun 21, 2010 | 11:02 AM
What about a 80-present chevy cavalier?
Yeah, I've seen them on G-bodies as well as FWD A-body cars (1982-up). It's hard to be certain from the photo, but the offset appears to be FWD. Interestingly, Olds had a FWD version of the Super Stock II/III wheels used on the Cutlass Ciera.
costpenn
Aug 29, 2018 11:42 AM
davbell22602
May 22, 2010 08:52 AM
snylften
May 15, 2010 11:13 AM
hooddm
Ninety-Eight
Jul 13, 2009 05:59 AM
mudjnky
Jan 14, 2009 08:02 AM
