what carb for sbo? what are you running
Old Jan 30, 2015 | 01:10 PM
GINCSC's Avatar
what carb for sbo? what are you running. looking for suggestions for a 71 convert 350 sbo.
Old Jan 30, 2015 | 01:11 PM
GINCSC's Avatar
will be running a performer intake
Old Jan 30, 2015 | 01:26 PM
What team for superbowl? what ball psi.
Old Jan 30, 2015 | 01:27 PM
Downtown442's Avatar
I put a Edelbrock 1806 on an Edelbrock 2711 intake last summer. Its a stock 350 rocket with about 92,000 miles on it when I changed over. Im quite happy with the results. IMO its a pretty decent set up right out of the box. I wouldnt hesitate to recommend it.
Old Jan 30, 2015 | 01:37 PM
Okay, I'll say it:
"What's wrong with the QuadraJet?"
Old Jan 30, 2015 | 01:48 PM
GINCSC's Avatar
Just bought the car and it has a factory intake and a 650 holley. From what I remember the qjet was a 750cfm. correct?
Old Jan 30, 2015 | 02:05 PM
Yes, the sixties-through-early '70s QJs would flow 750cfm, with some mid-to-later-'70s models flowing 850.
You don't need more than 650 for a factory SB, and a QJ is designed to properly meter lower air volumes than its rated maximum.
The Edelbrock (Carter AFB) has a fine reputation for good out-of-the-box performance and economy with no initial adjustments.
Old Jan 30, 2015 | 02:17 PM
GINCSC's Avatar
http://www.summitracing.com/parts/hl...hx7RoCxi_w_wcB
This is the carb that is on in now a holley 4175.
by the way go PATRIOTS!!!
Old Jan 30, 2015 | 05:54 PM
If that carb is working for you, it will work on your 3711 manifold.
Carl, uk
Mar 13, 2014 05:43 AM
coppercutlass
Jun 4, 2012 09:10 AM
Cameo White
Hurst/Olds
23
Aug 23, 2010 06:04 AM
f-85
Aug 15, 2010 11:15 AM
shaks 442 clone
Oct 18, 2008 09:41 AM
