what brackets can i use?
Old Feb 1, 2013 | 02:24 PM
deltaboy's Avatar
Hey folks, I want to move the alternator on my 307 to the pass. side.
Did they make a pass. side alt. bracket for sbo, or is there another that would fit, or am i gonna have to go custom, Thanks
Old Feb 1, 2013 | 06:29 PM
Dave Siltman's Avatar
Yes, just about any without A/C. However....... You must measure the water pump and get the corresponding pulleys to keep the belts aligned.
Old Feb 1, 2013 | 07:27 PM
deltaboy's Avatar
ok thanks alot. ill see what i can find in the junkard next week
Old Feb 2, 2013 | 09:53 AM
ANY 1968-1976 Olds V8 (big or small block) without A/C will provide the correct brackets. Of course, you will need the water pump and pulleys to match. The stock 307 long water pump will not work unless you get the pump pulley used on the HD cooling, non-A/C cars.
olddaz
Aug 27, 2014 06:39 PM
JpMotorsports
May 15, 2014 07:08 AM
Curth
Jun 25, 2010 05:24 AM
denis
Drivetrain/Differentials
Feb 28, 2007 07:12 PM
MAGIC253
Jan 2, 2007 04:32 AM
