What is the best carb?
I have a 1968 442 olds with a 400 engine that has been bored 30 over with a th400 trans and 373 gears in the rear. what would be the best carburetor for this car? I currently have an edelbrock 750 model 1411 but am not very impressed with it.
i completely agree with 380 racer. give us more details about your engine, cam, intake, headers? that sort of thing...
truth be told a well tuned Q-jet is a great carb but they aren't as easy to tune as a holley... if you have a squarebore (aftermarket) manifold i'd say keep tuning on that AFB, they are good carbs. if you are running an adapter on the stock spreadbore intake i'd go to a Q-jet and ditch the adapter
carb
The Engine has been bored 30 over like i mentioned and Im currently running the stock manifolds but plan to upgrade to some headers as soon as i get the extra money. Other than that it is pretty much a stock car but I want a good performing carb that I could take to the track every now and then.
agreed, fullstop.
A bigger carb is not always the better solution.
I also have a 1405 on my 350 rocket, it runs like a dream. Mechanical Secondaries. AND it seems to burn pretty clean. I havn't jetted it yet, its running like this out of the box.
carb
I have an edelbrock aluminum intake manifold and the car hesitates when i floor it. it doesnt necesarily hesitate in the begining but once it is running about 40 to 50 it is hesitating as if it is not getting enough fuel.
So maybe your carb needs to be rebuilt and adjusted.
Any more details on the hesitation?
Throttle positions affected (or only when floored)?
Does it catch up and then go fast, or does it bog until you release the pedal and try again?
Does it act like it wants to stall?
etc.
etc.
The carb sounds fine when i accelerate it in park. but when i run it hard it bogs . I just rebuilt the carb a month ago. could it be something else?
It bogs until i release the petal.
does not catch up
does not catch up
Could be advance plate in distributor binding, timing,... There is an adjustment for the acellerator pump. Watch the video.. I've had no problems running Edelbrock carbs over the years. They are usually pretty reliable.
http://www.youtube.com/watch?v=Kw-8l...layer_embedded
1968CutlassSupreme
February 8th, 2014 07:06 AM
