What is a 1969 W31 W30 exhaust heat riser pick up worth?
I'm looking for the value of a 69 W 31 W 30 dual snorkel heat riser pipe.
https://www.tapatalk.com/groups/real...3747&mode=view
The two parts attached to the snorkel.
Bernhard
Bernhard
the adapter with rubber grommet which attaches to the air cleaner, I've seen them for $20-$50. There are two styles and it looks like you have both in the pic, although one is partially cut off in the corner.
The actual hot air pipe is different for W-31 and W-30/W-32 as it's SBO and BBO, so the length is different. Those, well it depends on who you talk to. The SBO version is the same as all 68 SBO. However, I've seen people ask $100 for them. I've bought several for substantially less since it's not W-31 exclusive. Now the W-30/W-32 pipe, those I'm not sure of, but I will also guess $100.
bob p
April 30th, 2015 08:52 PM
1977 Delta 88 Flint
December 24th, 2012 11:25 PM
