Well... that escalated quickly!
If I wanted myself a project, now for sure I got one. Silly me thinking that a simple head gasket change would solve the problem...
Looks like a full top to bottom rebuild. That is, if I can reuse intake/heads without major machine work.
Pull it completely apart. Take the heads and block to a local machine shop and have them clean them in a "hot tank". Check them carefully for cracks. Have the heads magnafluxed.
Then, and only then, will you know if you have a rebuildable engine or scrap metal.
Count on re-boring the block, grinding the crank, re-surfacing the heads, and grinding and seating the valves at a minimum.
The machinist will guide you as to what needs to be done.
