welding an aluminum intake?
i took this to two professional weld shops. both have done work for me before and do great work. this manifold is leaking antifreeze out a bad spot in the casting. both shops are telling me that the way this is and as deep as it is, they don't think welding is a good idea. i am not a welder but i would think this would be an easy one. they said it needs to be ground out and that they will get it so hot building it back up they fear it will warp the intake. both places recommended to use a high temp devcon epoxy. i have used devcon on atv engines and is amazing stuff but thought welding would be best for this. what do you think? should i find a new weld shop?
http://cgi.ebay.com/ebaymotors/1962-...item1c244e2975
Intake Manifold
One of the problems of heliarc welding aluminum is that it has to be very clean. Because cast aluminum is somewhat porus, in that fuel and oil actually work their way into the metal, it becomes difficult to weld things like oil pans or intake manifolds. Anytime you hit oil or fuel contamination when you are welding it causes holes or flashes in your weld. You can use the high frequency to clean the area as you weld but it still can be a problem. Dave E
i see you have a problem with your aluminum intake i know a guy who can fix this or anything aluminum 1000% and his work is reasonably priced if you would like to contact him his e mail address is ... adamtshaw@hotmail.com...hope this helps
MATT
MATT
TIM FISKUS
May 12, 2013 05:17 AM
