Weird brakes
Old Feb 26, 2016 | 11:26 AM
edzolz's Avatar
Weird brakes
I have this in my shop to correct a brake problem!! One cylinder is front brakes and the other is rear brakes. Anybody ever seen this and why would anyone set up their brakes like this? Both ends are disk brakes.
edzolz
Old Feb 26, 2016 | 01:15 PM
I've seen them on Mustangs
http://www.autoworksracing.com/ford_...r_cylinder.htm
Old Feb 26, 2016 | 01:27 PM
This is a typical race car installation. Using separate M/Cs for front and back allows you to get infinite adjustability in the front/back brake balance. Typically, these dual M/C setups have a threaded balance bar between the two with an attach point in the middle for the pedal. By adjusting this attach point closer to one or the other of the two M/Cs, you can easily change the front/back bias.
http://pitstopusa.com/p-4167-balance-bar-adjusting.html
Old Feb 26, 2016 | 06:04 PM
edzolz's Avatar
That is exactly what is on this car, a 1970 Mustang. The owner wants to remove this setup and go back to a power booster and regular master cylinder.
Old Feb 26, 2016 | 06:46 PM
Should not be that big of deal, its only money and parts...
72allblackcoupe
Apr 6, 2014 07:20 PM
1carsick
Brakes/Hydraulic Systems
23
Oct 2, 2012 05:50 PM
russell-t
Apr 30, 2011 05:56 AM
chadnum1
Apr 30, 2008 11:12 AM
1BAD68"S"
Nov 17, 2006 04:20 PM
