water pump ?
Old Jan 23, 2014 | 12:51 PM
tomc5's Avatar
water pump ?
'72 cutlass 350 I have eliminated a/c , have brackets for alternator to pax side w/ correct pulleys per olds build manual and the water pump pulley is 0ne groove to far forward. The books say the pump should be 5.572", but it looks to me a 5" pump would work an make all grooves align. Am I correct? Thx, tomc5
Old Jan 23, 2014 | 01:20 PM
Mr Shifty Sidney's Avatar
71/72 with
A/C use 6" pump
W-30 non A/C use 5.5" pump
Non W, non A/C use 5" pump
If you have switched brackets and pulleys, the 5" pump should work. Non A/C water pump pulley is different than A/C pulley. Crank pulley is probably different also, cant remember for sure.
Don W
Old Jan 23, 2014 | 08:00 PM
Any parts store should be able to get the 71/72 5" pump. If you want the factory correct pump it will be casting #408328. Also identified by a "1" casting at top of pump. I have a core if you need it.
Don W
Nor Cal Andy
Mar 29, 2012 07:27 PM
72Ctlss
Jun 23, 2009 03:12 PM
greener_dude
Feb 18, 2007 08:14 PM
SMOKEYMTNKUSTOMS
Jun 21, 2006 04:42 AM
SMOKEYMTNKUSTOMS
Feb 21, 2006 11:16 AM
