Water in convertible trunk
I did a search but I must be searching incorrectly as I couldn't find this... I have a 1970 Cutlass Convertible, well I have had it 10 days, and when I washed it water got into the trunk clearly from the seal behind the convertible and not the trunk seals. Any recommendations on how to solve this?
have a conv. top guy loo at it. There is suppused to be a plastic rain gutter in there that channels the water off to the side and disposes of it. Maybe that part is missing or broken. IT can probably be welded [yes plastic welds] or fixed with epoxy, silicone, or the like. JB Weld and window screen... get ingenious.
Ah I found it under rain gutter...
https://classicoldsmobile.com/forums...tallation.html
now I just need to deconstruct the back seat it seems!
A longtime Olds guy I know once said "it ain't a real convertible if it don't leak!"
But yes, check the plastic gutter and make sureit channels water around to the wheel wells.
Hey, at least you got a real gutter. The 71-76 fullsize convertibles have a gutter made of top material, and if it gets a hole in it or even gets scrunched up, you got a trunk full of water. And you rarely see a trim shop replace or even check that gutter when they do a top job on one of these cars, even when you specifically tell them to.
shamusj
Apr 7, 2018 08:10 AM
