warning: seller
Old June 21st, 2013 | 02:50 PM
androm's Avatar
warning: seller
Do not buy from this seller anything, he knows how to cheat, and do' nt know what he is selling.www.gmobsolete.com, name Jerry Hammer.
Old June 21st, 2013 | 03:08 PM
59-59-59's Avatar
We really appreciate all the information that was given to us. Care to tell a story behind it?
Old June 21st, 2013 | 03:21 PM
X2 - there must be a story.
Old June 21st, 2013 | 03:42 PM
androm's Avatar
The issueis part of the fuel sendingunit . On the page of the company
Is visible this part cylider shaped like for 1969 Toronado it shouldbe. To me wastold that these are also sold to Toronados. I trusted him and I paid $ 270 postedto my country, as well as the rate of customs.But the part was 1 inctoo short, but it works, but the tank remains empty after the emty point of gasoline. Scamwas there that was not part of the fitting, however,he claimed Toronado owners bought them.
Thank you for reading
Old June 21st, 2013 | 03:53 PM
androm's Avatar
Edit:.. In the tank remain gas after the emty point..
Old June 21st, 2013 | 05:12 PM
There is supposed to be some gas in the tank when the gauge initially reads empty. It's a built in reserve to allow you to get to a gas station before completely running out of fuel. The old fuel gauges were inaccurate in accordance with the markings and how much fuel was in the tank. In other words it could stay between 1/2 and full for what seemed like forever, and then drop really fast from 1/2 to empty
Does your gauge read full when it's full? It is normal for the gauge to go past full if it's filled all the way to the neck.
Old June 21st, 2013 | 06:04 PM
androm's Avatar
This thing is pretty new to me now, but I assume that the gauge reads correctly full and emty, because the resistance is the same as the original gauge. In any case, this new one is shorter than the orginal. Let's see how it works, maybe I ll learn to live with it.
But the seller was anything other than an expert.
Old June 21st, 2013 | 06:10 PM
Octania's Avatar
To me it sounds like the seller misrepresented the part as fully correct for the buyer's car, whereas in reality it is 25mm short and does not draw all the available fuel from the tank. Some users may consider this a problem.
On the other hand, when putting in new parts, the installer has the duty to check against the old part, and verify that it is functionally acceptable. Sounds to me like it just needed to be modified to suit.
It's not like you can just get another one.
Old June 21st, 2013 | 08:23 PM
BILL DEMMER's Avatar
Just the facts...
i've bought from him once, in the past, no problems with a headlight bezel for a '73 delta.
bill
Old June 21st, 2013 | 09:32 PM
Maybe I misunderstood, I thought he was saying that the tank wasn't actually empty when the gauge read empty, not that it would not pickup the most of the remaining fuel.
Old June 21st, 2013 | 09:44 PM
I think it's both with those senders - the sender is also the pickup and is supposed to essentially touch the bottom of the tank.
If it isn't long enough, you can lose a significant amount of your fuel capacity.
mrolds69
February 20th, 2012 10:25 AM
MJAKS462
April 13th, 2010 09:14 PM
KQQLCAT
March 24th, 2008 08:48 PM
lowrytd
March 10th, 2008 11:45 AM
