Wall of shame
Old January 9th, 2016, 10:06 PM
  #201
Originally Posted by oldstata
They drive among us
Good sheetmetal work. I think I would've just made a bracket for the strut and ran square tube to someplace solid to bolt onto, but yours will look fixed right.
Koda is offline
Old January 9th, 2016, 10:51 PM
  #202
Justin
oldstata's Avatar
I actually didn't fix this. I believe the owner did, I have my own concerns of this repair as to alignment specs and such. This. Was on a face book group and I have never seen a strut tower rot out like this before
oldstata is offline
Old January 11th, 2016, 07:05 AM
  #203
NOVICE car nut
oldsguybry's Avatar
Depending on what the rest of the car looked like I probably would have done the same thing . Concerns about specs and other things of that nature go right out the window when that's the only car you have and can't afford another one . I'm not sure if that's the reason this guy did this repair but it looks pretty good to me . I'm not sure if it's " Wall of Shame " worthy .
oldsguybry is offline
Old January 11th, 2016, 08:37 AM
  #204
I agree. Sometimes you can wing something by just building to where the car wants the part to be, but it's never going to be right. Best thing to do would have been to walk away; second best would be weld in an entire apron panel.
Koda is offline
Old January 17th, 2016, 05:15 PM
  #205
costpenn's Avatar
Here's a Olds specific contender. Found this little gem during head bolt clean up my 71 350. Looks like someone didn't know you can just leave the stud alone if not used, or the guy didn't have a deep socket.
costpenn is offline
Old July 1st, 2016, 05:02 AM
  #206
Rocketguy's Avatar
Rollin'
I saw this in the salvage yard yesterday:
Rocketguy is offline
Old July 1st, 2016, 06:42 AM
  #207
Is that an S-10 Blazer wheel?
MDchanic is offline
Old July 1st, 2016, 12:09 PM
  #208
Funkwagon455's Avatar
Depending on where one was when the tire failed, you might have done the same thing. IE: Bad neighborhood at night, in the desert with no phone/signal, getting chased by brain starved zombies!!
Funkwagon455 is offline
Old July 1st, 2016, 12:35 PM
  #209
Ca's Only Official OLZNUT
66 Olznut's Avatar
I'm gonna guess mid 90s Tahoe.
66 Olznut is offline
Old July 2nd, 2016, 03:54 AM
  #210
Rocketguy's Avatar
It's a six lugger. I'm guessing early '00s Tahoe Suburban
Old July 2nd, 2016, 04:54 AM
  #211
NOVICE car nut
oldsguybry's Avatar
My guess would be the zombies !
Old July 2nd, 2016, 04:57 AM
  #212
svnt442's Avatar
I'm thinkin' high speed chase on a blown tire.
svnt442 is offline
Old July 4th, 2016, 09:05 AM
  #213
johncj5's Avatar
I don't know if this is "Wall of Shame" worthy.
It's just trail fix... a broken main leaf clamped to the rest of the leaf pack to get my Jeep out of the woods and home, and then to get the spring replaced.
johncj5 is offline
Old July 4th, 2016, 10:01 AM
  #214
Professur's Avatar
Nothing Fail about that. Fail would be if the clamps were rusted.
Professur is offline
Old July 4th, 2016, 03:17 PM
  #215
marxjunk's Avatar
man..you need brake lines....stretching it like that..bad mojo...fixing the spring...nice
marxjunk is offline
Old July 5th, 2016, 07:01 AM
  #216
NOVICE car nut
oldsguybry's Avatar
OR if he had it held together with a coat hanger or something
Wait until I post some pics on my Buick .
Old July 5th, 2016, 07:48 AM
  #217
Hookers under Hood
76olds's Avatar
I never liked that truck anyway haha !!
76olds is offline
  #218
johncj5's Avatar
That's the e-brake cable that looks stretched due to the angle of the pic.
I sold that Jeep a few years ago, but I keep those clamps in the one I still have in case I break another spring.
johncj5 is offline
Old July 5th, 2016, 10:21 AM
  #219
cutlassjoe's Avatar
In high school a buddy of mine had an old Ford F-150. The power steering pump leaked. His solution was...every other day he would put in a large McDonalds chocolate shake. the stuff was so thick it would work for a couple of days. When the pump would start to whine he would just refill it. It was hilarious because you could smell the shake in the cab of the truck. She was pretty much on her last leg and full of rust. Within a few weeks she went to the wreckers...
cutlassjoe is offline
Old July 5th, 2016, 10:53 AM
  #220
marxjunk's Avatar
i see.....
marxjunk is offline
Old July 6th, 2016, 06:15 AM
  #221
NOVICE car nut
oldsguybry's Avatar
At least SOMEONE finally found a use for a McDonalds shake that doesn't require a trip to the bathroom .
Old July 11th, 2016, 03:32 PM
  #222
Justin
oldstata's Avatar
See anything wrong ? Hahah
oldstata is offline
Old July 12th, 2016, 06:39 AM
  #223
Hookers under Hood
76olds's Avatar
Somebody's husband will be going nuts after they see that. Haha, good pic!!
76olds is offline
Old July 12th, 2016, 08:13 AM
  #224
Or somebody's wife will be yucking it up with her friends about "Mr. Fix-It."
MDchanic is offline
Old July 12th, 2016, 08:31 PM
  #225
Justin
oldstata's Avatar
Not sure on this one if it qualify' sir not may need to zoom out n on the pic look at the zip ties
oldstata is offline
Old July 13th, 2016, 06:59 AM
  #226
ostie13's Avatar
with a motor as perty as that who needs a hood. Probably blew off.
ostie13 is offline
Old July 13th, 2016, 07:20 AM
  #227
Justin
oldstata's Avatar
If you zoom in their is a box end wrench sticking up and zip ties holding rad support to box end wrench
oldstata is offline
Old July 13th, 2016, 07:54 AM
  #228
marxjunk's Avatar
ive done worse with zip ties...just sayin'
marxjunk is offline
Old July 13th, 2016, 08:26 AM
  #229
Had a buddy whose starter motor was zip-tied to the block of his Toyota pickup about 20 years ago.
The starter on those is held straight into an indexed flange with 2 bolts, so the axial force provided by the two zip-ties through the bolt holes was enough to do the job fine.
MDchanic is offline
Old July 13th, 2016, 08:40 AM
  #230
Gary M's Avatar
Hood must have been zip tied on too.
Shopping list:
1. Hood
2. Bigger zip ties
Gary M is offline
Old July 13th, 2016, 08:41 AM
  #231
Justin
oldstata's Avatar
I am just curious if he welded the wrench into the manifold or bolted it to the block
oldstata is offline
Old July 13th, 2016, 09:19 AM
  #232
CH3NO2 LEARN IT BURN IT
droldsmorland's Avatar
As the "other" Eric says..."Theres nothing cant be solved with suitable amounts of explosives"
droldsmorland is offline
Old July 13th, 2016, 09:42 AM
  #233
Mr. Johnson
rjohnson442's Avatar
If he had a welder I don't think he would be using zip ties lol.
Cousin had a Plymouth breeze and it was a two man job to start the car for a couple months, one to turn the key and one to hold the starter in place.
rjohnson442 is offline
Old July 13th, 2016, 10:43 AM
  #234
marxjunk's Avatar
i have zip ties that are almost 4 feet long and 1/2 wide.......im willing to donate them if someone does something really dangerous with them....oh..on their car...no weird stuff...i aint into weird stuff..i cant be responsible for weird stuff going on..
marxjunk is offline
Old July 13th, 2016, 03:40 PM
  #235
Hookers under Hood
76olds's Avatar
i have zip ties that are almost 4 feet long and 1/2 wide.......im willing to donate them if someone does something really dangerous with them....oh..on their car...no weird stuff...i aint into weird stuff..i cant be resonsible for weird stuff going on..
I prefer AA batteries. That keeps er' motor runnin'.
Put-r-ther
76olds is offline
Old July 23rd, 2016, 09:09 PM
  #236
Justin
oldstata's Avatar
Found this today lol
Asked if they wanted it replace no charge for labor just a new filter was advised but I could fix the old one as its not that dirty
Response
Really your saying my brother who is a mechanic installed it wrong ? Well I don't think so there is obviously a reason he installed it that way put it back just as you found it
Hahaha
oldstata is offline
Old September 17th, 2016, 05:25 AM
  #237
Justin
oldstata's Avatar
hummmm in a pinch and you couldn't find anything better ?
oldstata is offline
Old September 17th, 2016, 07:07 AM
  #238
Mr. Johnson
Ahh ha ha! That must be the original design for those fuses that light up when it blows so you know which one it is.
Old September 29th, 2016, 08:42 AM
  #239
Justin
oldstata's Avatar
Imagine driving next to this guy doing 80 in a construction zone
oldstata is offline
Old September 29th, 2016, 08:57 AM
  #240
Seriously? That is amazing.
Where did you get that photo? Did you take it yourself? Was someone actually driving that car?
Wow.
MDchanic is offline
Quick Reply: Wall of shame
