w30 specs
w30 specs
Is there a Factory OLDSMOBILE Sheet telling u what u got added to the 442 when u ordered a w30 option. Have heard this and that and ---------- but never have seen a Factory thing.
I have a 1971 w30
I have a 1971 w30
The salesman would tell you when you bought it; there would be brochures, and the window sticker would as well. We here like the SPECS booklet, if you google 1971 oldsmobile specs booklet there's a huge scanned pdf with it in the middle of it.
Pictures below. It says (summarized): Special V8, everything Outside Air Induction related, quadrajet, aluminum intake manifold, sport mirrors, certain tires, stripes and badges, less insulation, and manual disc brakes.
I think the quadrajet is a mistake as a 442 got one, so it, by its name, is not an upgrade, although it WAS a different quadrajet internally, I believe.
The exact content of RPO W30 varies by year. There are plenty of factory documents that spell out exactly what was included. As Koda points out, the SPECS booklet provides the details, as do the Inspector's Guides for each year, and the associated dealer ordering info sheets. Are you asking about a particular year?
All this is great guys BUT!!!!!!!! seems like the given piece of info are missing things O R am i wrong?
U have to understand im the new guy on the block who has just owned a '71 w30 for 6 months.
From what ive pieced together diff between a std 442 and a w30 is or r some of these BS????
W30 Badge
Hood w/ Air Cleaner
Intake Man WINTERS Just for weight?
Heads Larger Valves
Diff and Larger Ext Manifolds
Heaver Sway Bar
Diff Carb
Cam with a longer duration
Diff rear end ratio
OW trans if AUTO
Strips etc
Larger dia exhaust pipe
Diff rear bumper with cutouts
Larger radiator
R E D fender well
Raised letter larger tires
Heavier rear shocks
Interior diff than 442
Alternator lager output
Anything else????????
Is all this true ??????????? or BS. Is there an OLDs sheet that details what u would get ?????????
W30 Badge
Hood w/ Air Cleaner
Heads Larger Valves
Heaver Sway Bar
Diff Carb
Diff rear end ratio
OW trans if AUTO
Strips etc
Larger radiator
R E D fender well
Heavier rear shocks
W30 Badge
Hood w/ Air Cleaner
Heads Larger Valves
Heaver Sway Bar
Diff Carb
Diff rear end ratio
OW trans if AUTO
Strips etc
Larger radiator
R E D fender well
Heavier rear shocks
W30 Badge
Hood w/ Air Cleaner
Heads Larger Valves
Heaver Sway Bar
Diff Carb
Diff rear end ratio
OW trans if AUTO
Strips etc
Larger radiator
R E D fender well
Heavier rear shocks
The items ive listed r what ive picked up from Articles - Forums - What specs i can find -writeups on w30 for sale. Im sure some r true and other BS or SHE SAID HE SAID. Love to c an OLDSMOBILE thing that outlined what u got when u ordered a '71 w30. Seems the 2 piece given in the Thread are missing info.
Any third party source (articles, websites, forums, and ESPECIALLY sellers) should be taken with a grain of salt. The ONLY reliable source is direct factory documentation. If you care that much, spend the money and buy yourself a high quality copy of the 1971 Product Information Manual (PIM), commonly called the assembly manual. That document is made up of copies of the engineering drawings the factory used to assemble these cars, including part numbers. They will tell you exactly what parts were used and what options were available. Of course, you need to be able to read engineering drawings. These are not intended as marketing materials for the general public. The Inspector's Guide will also list the parts that go along with specific RPO codes. You can buy one of those too if you care to learn the details.
