Morning all,
Below is a picture I see online quite a bit of a w-30 motor. The battery cables appear to be red for the positive and black for the negative. Also the + runs over the top of the intake? (I've currently got two blue that are ready for replacement). Would this be the factory set up? Also any other cable details would be appreciated. Seems pretty straight forward 1 GA wire.
Morning all,
over the intake is the manual shift configuration. Auto cars ran along the drivers fender well.
Here is a chart I found online showing gauge and amps with maximum recommended cable lengths, minimizing voltage drop. You can see that the 2 gauge only handles 300 amps at 4.9 feet. Your positive cable is 55” (?) somewhere around there. 2 gauge wouldn’t handle the amp draw without potentially damaging other electrical components.
Are we talking about the cold cranking amps of my battery? Which I believe is 720 or 730.. because according to that chart even the one gauge that was in there would only handle 300 at 6 ft. Mine is 50".
Bigger is better, BUT the factory only used 4ga. Not sure about the rear mount W-30 battery installs, though. While not concours OEM style, batterycablesusa.com will make custom cables to length in just about any gauge you want. These are 1ga.
I'm not trunk mounting. Sorry if I gave that impression. Agreed most cars I see are 4 GA or smaller. I'm going with the 2. Thank all for the help as always!
I have been waiting for an M&H spring ring clamp battery cable for almost a year.
The story I got was there was some issue with getting the metal/lead to pour the spring rings.
I went with Midway Muscle Cars cables. I used 69 cables so I had both spring clamps and I routed the positive cable over the valve cover to clear my headers. https://midwaymusclecar.com/
