vibration/shimmy
Old August 4th, 2015 | 11:45 AM
bigred1972's Avatar
vibration/shimmy
Just looking for opinions on where to start looking for the cause of a vibration or shimmy in my 1972 Cutlass Supreme Convertible, you can feel it at around 40mph, you don't feel it at all when the car is under heavy acceleration. The car has 77,000 miles on it , the original drivetrain, It is not wheel or tire related as I have two sets and it occurs with both, I was just wondering what I should start changing and if anyone has experienced a similar thing. Thanks Marty
Old August 4th, 2015 | 02:00 PM
toymobile's Avatar
Lose parts in the steering, IDLER ARM, tie rod ends, center link, one or all of the above.
Raise car off the ground and grab the tire FRONT AND BACK try moving back and forth and you will feel the lose motion if any, Might need to get a friend to see what is not moveing in time with everything else or up and down motion in the idler arm. Good luck.
Johnny
Old August 4th, 2015 | 02:18 PM
RetroRanger's Avatar
72 Olds CS
front or rear of the car?
original drivetrain could be bad u joints easy enough to drop the DS and check them or replace them
lionelbob
May 27th, 2010 08:10 PM
yeahbuddy
May 7th, 2010 08:54 AM
ziff396
February 15th, 2010 11:59 AM
Robert Kiedrowski
October 10th, 2009 10:36 PM
bo1962
June 22nd, 2009 01:33 PM
Quick Reply: vibration/shimmy
