vanity mirror installation
Old Feb 26, 2010 | 06:30 PM
ELECMAN's Avatar
I wanted to install a vanity mirror on my passenger side visor.The mirror came with two plastic clips attached to the mirror how does it get installed on to the visor.
Old Feb 26, 2010 | 06:44 PM
The mirror has two plastic clips on the back that compress when inserted into the visor. Here's what you do.
Make a template of the mirror out of light cardboard or paper. Cut out the template and center it on the visor. Mark the location where the holes will go.
Now take an exacto knife (or olfa) and cut out the cloth in circle around that hole location. My factory visors have a round cutout about 1 inch in diameter. Re-apply the template and mark for the 2 holes you have to drill. I'm not sure if it's 1/4 inch or a little bigger and I don't want to take mine off in the cold in case it breaks. Check your mirror back pins against the drill bit. You might want to drill a couple of test holes in cardboard to see how the fitment will be. (I suggest cardboard in case your hole is too small, it's easy to remove the mirror without breaking it)
I would recommend taking the visor off the car when you drill the holes. Be very carefull and drill slowly and use VERY LIGHT pressure. You want to drill through the fibreboard in the visor, but not out the other side. Press the mirror into these 2 holes and reinstall the visor.
Old Feb 26, 2010 | 06:57 PM
ELECMAN's Avatar
Thanks Allan for the info
Old Feb 26, 2010 | 08:01 PM
ELECMAN's Avatar
worked mint drilled two #7 holes in the visor popped the glass in looks great.did what you said worked mint
jensenracing77
Jan 14, 2012 03:21 PM
stevengerard
Feb 21, 2011 02:25 AM
buickfarmer
Apr 18, 2010 06:40 AM
mv213
Jan 19, 2010 08:18 PM
mv213
Sep 21, 2009 07:25 PM
