valve covers
Old Nov 11, 2015 | 07:29 AM
hookem horns's Avatar
valve covers
These came on my car but I don't see any manufacturer ID on them. I like the no logo look but does anyone know what brand they are? I pulled them to work on a top end tick. Notice the small wear marks on the breather hole, could be at least part of my problem. Plan to replace all the rockers/perches and check all the pushrods, you know, might as well.....
Old Nov 11, 2015 | 07:38 AM
2blu442's Avatar
I've got a set that I believe may have been Hardin Marine covers. Someone ground off the name and painted them with black wrinkle paint. They came out looking nice. I'm thinking someone may have ground off the brand on yours (Edelbrock?) and polished where it had been.
John
Old Nov 11, 2015 | 07:39 AM
Should have done this first. Googled the part number on the inside which indicates Holley, but all the Holley's I have seen have the embossed name. Maybe they just used a sticker at some time.
Old Nov 11, 2015 | 07:47 AM
redoldsman's Avatar
Proud Viet Nam Veteran
The fact they say 330-425 instead of 455 may date them. That part number is the correct amount of numbers for a GM part number. That is probably coinsidence.
Old Nov 11, 2015 | 08:26 AM
rob1960's Avatar
Those are the old M/Ts that someone machined away the "M/T". I liked the look of them but I hated that they still used the very early Toro style offset holes which made it hard to hook up the breather parts if you wanted to run a stock air cleaner
Old Nov 11, 2015 | 09:18 AM
They could be Holley also.
http://www.ebay.ca/itm/Oldsmobile-Fi...-/111784987115
Old Nov 11, 2015 | 03:44 PM
edzolz's Avatar
All of this style of valve covers were cast by Offenhauser for whoever wanted their logo on them. Some were Edelbrock, some Hardin Marine, Holly, etc... I had a set one time that actually had Offenhauser logo on them.
Old Nov 11, 2015 | 03:58 PM
I always thought the Offy covers had less fins.
Old Nov 12, 2015 | 07:43 AM
Not sure if it was Offy but I agree it's very likely the same foundry cast these with various logos (or no logo in this case). There's a slight recess (1/64th?) within the space where the logo goes with what looks like a tiny bit of mold flash. Don't think it was milled out or that would have been cleaned up by polishing the machine marks. Way too exact for a grinder.
I like them with no logos and will clean them up a little but not full polish before re-installing. Probably too flashy for me, but thought about painting the recesses with engine block gold.
Need to figure out my ticking issue this weekend first.
Old Nov 12, 2015 | 08:45 AM
They are really easy to cleanup and paint, wait a few minutes and wipe the tops of the fins with acetone on a rag with your finger tip.
Old Nov 13, 2015 | 08:22 PM
Do you like or did I enter the "pimp my ride" zone?
Old Nov 13, 2015 | 09:07 PM
z11375ss's Avatar
Senior Moment Member
I like it!
Old Nov 14, 2015 | 03:47 AM
cdrod's Avatar
Rodney
X2! That's exactly what I want to do with my small block stroker build. I like the combination of polished aluminum with the Olds gold accents and no logos.
Old Nov 14, 2015 | 04:46 AM
Perfect
Old Nov 14, 2015 | 05:23 AM
Rocketowner's Avatar
Those look great,now I hope you can find your "little tick" and it don't come back when you Install the valve covers again. Best of luck, Larry
Old Nov 16, 2015 | 08:11 AM
Replaced all the rockers/perches and 95% sure the tick is gone. Getting dark and starting to drizzle when I finished yesterday so did not road test it yet. One rocker on the driver side had a bit of play. One bolt on the passenger side was loose, turns out it was a regular bolt with a washer that had cracked. I think the no-name valve covers with the gold accents turned out good since my engine bay is not stock original anyway.
RAMBOW
Mar 20, 2017 06:58 PM
jpc647
Oct 12, 2012 03:11 PM
Ric
Oct 23, 2011 05:32 PM
HWYSTR455
Aug 30, 2006 04:40 AM
derek42
Aug 28, 2006 11:37 AM
