Valve cover breather removal.
Old Mar 12, 2023 | 08:30 PM
Redbud40's Avatar
Is there a trick to removing the stock breather cap and tube from a 72 CS. The top part seems to just spin and I used quite a bit of pull at the cover with no luck.
Didn’t want to break something off and have it fall inside the cover. Thanks
Mike
Old Mar 12, 2023 | 08:59 PM
bccan's Avatar
Upward pressure, wiggle, twist, simultaneously. There is a raised bead on the breather that has formed a groove in the grommet. Might be time to replace that hardened grommet.
Old Mar 13, 2023 | 04:42 AM
Oldsguy's Avatar
Past Administrator
The rubber grommet gets really hard over time with heat of the engine, unfortunately pulling real hard on the breather is the only way and if a piece of rubber breaks off the grommet there isn't much you could have done to prevent it.
Old Mar 13, 2023 | 05:33 AM
Redbud40's Avatar
Thanks. Guys. Went at it with allot of pull this time and it busted loose. I don’t think I lost any of the rubber. Looking for a new rubber gasket now to replace the worn out one.
REO442
Dec 17, 2022 07:37 AM
Donaldbabineau
Jan 2, 2022 04:05 PM
HighwayStar 442
Sep 5, 2017 09:15 PM
defiant1
Mar 23, 2011 07:50 PM
eric72
Feb 24, 2010 06:43 AM
