Vacuum advance revisited.
Old Mar 14, 2008 | 11:16 PM
88 coupe's Avatar
Junior Member
A sidebar to this thread beginning at post #4, with the following exchange:
Originally Posted by goodkarmech
........ make sure both the centrifugal and vacuum advance mechanisms in the distributor are functioning correctly and that the initial timing is set right for your engine.
Originally Posted by 88 coupe
Vacuum advance has nothing to do with power output.
There is a longtime running debate over vacuum advances and what they do. I agree that on race engines it is seldom used. Not to step on anyone's toes, but I respectfully disagree with broad statements like vacuum advance has nothing to do with power output. Rather I would say that it depends on what type of power you are talking about. Vacuum advance has a lot do do with part throttle power, good driveability, throttle response, and fuel economy on a street driven vehicle. If you are running near redline most of the time, then it is not necessary, centrifugal only is sufficient. Also, if the source to the advance is ported vacuum and not manifold vacuum, then the supply to the advance will not be zero under a load. This article may be of interest:
http://65corvette.nonethewiser.net/t...um_advance.pdf
It is mainly aimed at corvette owners, but good reading.
This is aimed at Pontiac owners, but also good info:
http://www.highperformancepontiac.co...uum_curve.html
I brought this topic up because the last word of the thread opener was inexpensively, and these 2 important distributor components are often overlooked. Centrifugal advances get stuck, lose weights and are easily repaired, or modified for more or quicker advance curves. Vacuum pots blow diaphrams and stop functioning entirely. Many late 60's and early 70's Olds engines had devices to limit the vacuum advance for reduced NOX emissions, ie transmission controlled spark advance and if they are malfunctioning, power output will be down and fuel economy will suffer. If you are driving a hot rod, chances are you have already bypassed these devices, but if you are driving a stocker you may want to investigate whether they are working correctly given that gas is hovering at 4.00/gallon.
Good post.
........ There is a longtime running debate over vacuum advances and what they do .........
It continues because few, if any, of the participants fully understand the concept.
........ disagree with broad statements like vacuum advance has nothing to do with power output ........
As my statement was applied to this topic, I disagree with your disagreement.
........ if the source to the advance is ported vacuum and not manifold vacuum, then the supply to the advance will not be zero under a load ........
Not possible. Both positions draw the same vacuum, from the same source.
Corvettes, Pontiacs, Oldsmobiles, and Volkswagens, are all subject to the same laws of physics.
In this case, both authors advocate the use of “full time” manifold vacuum to “improve” the idle of a performance cam. Nothing but a band aid to cover a mismatched advance curve.
Norm
pcard
Feb 11, 2013 05:09 PM
Redog
Jun 21, 2012 08:05 AM
djcrook73
21
Feb 25, 2012 10:37 AM
a6m5zerosen
Jan 3, 2008 05:44 AM
harleyrules
Nov 16, 2007 05:27 AM
