V6 diesel
V6 diesel
Forgive the link to an outside site, but WOW! This is very cool in a perverse sort of way:
http://www.hotrodders.com/forum/olds...ml#post1479884
Certainly a nice looking setup, but why go to all that trouble to gain I suspect very little?.
I know modern diesels can have their power output upgraded but I always thought the Olds diesel was near the limit of what the bottom end could handle.
Roger.
Roger.
All we get up here in Canada is the 83-87 Camaro's and Fire Chicken's.
Perhaps i'm biased, but having driven in the Unibodies and such, my Olds feels alot more "solid" and wider on the road.
I could be wrong, but that's my 0.02$ on the chevy world.
Cheers,
Tony
Joe, could you post over there for me? If he is getting oil through the lifter, it isn't the problem, but he can increase oiling by drilling a small hole offset from center in the metering plate under each button. I found about .087" diameter to be good. He should make sure the pushrods are sending the oil freely.
The local Massey-Ferguson dealer is closing after 65 years, and we haven't had a Harvester/Case dealer in years. Kubota and Mahindra have really dented domestic tractor sales here.
Again, the Olds Diesel's relative failure can be traced back to being underengineered. The DX block makes a helluva gas racing engine though!
One of those little Diesels showed up at Seven Springs and its clatter was like a Pied Piper to a bunch of rats. There was a herd of people following it to its show spot.
The US needs to embrace Diesel technology for passenger cars more than it has. Only trouble is Diesel fuel would never drop price if that happened.
Joe D --- Too bad I dont have HIS problem - eh? I have way too much coming up through the pushrod on mine and need to "undrill" the holes in the lifter plate!! Everyone has a different problem!! LOL !
His little motor would go great im my model T project!!!
hello every on. am one with the motor. after long shot i fix the problem. it seem that the stock lifter design (i reused the stock lifter as they hadn't worn yet at 60k) is different then the seal power designed ones. which have a better oil restrictor design and flow better
i'm going though the trouble for a few reasons. one hot rodding has gone way soft. at his point any monkey can build and make so SB or BB with a little parts matching. two i wanted to know what she could do, and to try something new (including a custom manual trans swap)
my mods should be good to 200 ftlbs @1600 when i finish a better flowing upper intake tube. from there 8-10psi out of a super should give me about 300 ftlbs (or that's the goal) i dont have room for a turbo in the century so a procharger will have to do.
the bottom end i think will hold 400lbs as i know a guy in that has build like mine less the Harland rockers that put down about 300 with 12 psi. he is working on a build with the Harland rocker set up after a valve loss thrash that motor at 40k.
glad you guys like the build.
+1 to 440 old build of the DX 350 blocks.
Good luck and please keep us updated with how your project progresses.
Roger.
