Trying to prime engine with oil-HELP!
I am putting together a '68 Olds 400, I am trying to prime the engine with oil. I was spinning the pump with a drill, getting good resistance, the lifters filled with oil and then the drill started basically free spinning as if I lost all oil pressure and oil would not push up through pushrods. Is there any other oil plugs inside the engine? I only know of four, two in the rear and two in the front on either side of the camshaft and one of the two in the front has the tiny hole for oiling the timing chain. Can anyone possibly tell me what went wrong? Thank you, Jay
As stated above the Olds engine distributor and oil pump turn counter clockwise. Verify this first. I install a manual guage in place of the oil sending unit to monitor oil pressure when I do this.
How much oil was in the engine?
Was there enough oil to prevent the pan from being emptied? If there was only two quarts or so perhaps the pan was emptied before the oil ran back down. Can you see through the drain plug hole to tell if the pick-up came out of the pump?
it is possible it could hurt a mechanical gauge but that would only be for the first second at most. if there is oil in the galleries it would suck that oil out and after that it would read zero. shouldn't really hurt anything, just reverse the drill and see if the gauge is working.
![Wink](https://classicoldsmobile.com/forums/images/smilies/wink.gif)
John
I use an old distributor shaft in my 1/2 reverible drill. Cut a short piece of heater hose (5/8 I think) on the end of the shaft. It will help keep the shaft end in the slot of the pump drive shaft.
not messing with anyone. if the oil pump is turning backward it is not going to pump oil through the engine. the oil will just sit in the pan. did i miss something?
I have always primed the engine manually. I use a 1/4" drive ratchet, extension, and deep well socket held onto the long extension with duct tape. When I hear the oil squirting and get heavy resistance, I stop. I fill the lifters if hydraulic before installing by putting them in a cup filled with oil and depressing the plunger several times. Since I have moly cam lube on pushrod and rocker tips and on the rocker pivots, they can wait for full oiling.
John
Olds has a 5/16" hex shaft.
No slots. No tangs.
A pump, spun backwards will attempt to pump backwards
ATTEMPT being the key word here...
with the "pickup" now being above the pump, in short order it will take in nothing but air which will leak past the gears and pretty much do nothing.
Only if it doesn't have a check valve, and the impellars are designed in a manner that allows reverse pressure... and actually, I can't remember if the Olds pumps have a check valve.
depending on your classification of "plugs" yes 4 threaded plugs
and 1 freeze plug style in back of block that covers access hole to
the inner threaded plug in oil galley . ( I forgot which side of block that
bugger is on but if someone missed putting that one in you'll spin that pump till eternity and never get pressure reading
So can we put this one back to bed? After two years threads tend to get cranky when their woken up by rhetorical questions
