transmision Mount
Old Sep 7, 2019 | 02:09 PM
servexcell's Avatar
transmision Mount
i am replacing the drivetrain in my 68 Cutlass S Convert. I am installing a 68 400 cubic inch motor and turbo 400 transmission. i have the engine driveshaft and transmision. i am going to order a new trans mount . Are they all the same. Who sells them. are they the same for all transmisions
thanks
Old Sep 7, 2019 | 02:13 PM
The T350 and 400 mounts are the same. You can buy one at your local parts store.
Old Sep 7, 2019 | 02:20 PM
servexcell's Avatar
thank you very much Eric.
Old Sep 8, 2019 | 04:45 AM
rob1960's Avatar
The mounts aren't the same for a 350 & 400 trans. TH400s have a slightly wider bolt pattern. They should be easy to locate. You'll have to move your crossmember back for a Th400. The holes are in the frame for it.
Old Sep 8, 2019 | 09:45 AM
72GoldOlds350's Avatar
This is accurate.
servexcell
Apr 25, 2017 07:48 PM
rookieoldsguy72
Apr 8, 2016 07:54 PM
442tom
Dec 28, 2013 11:04 AM
hurst68olds
Jan 10, 2012 11:49 AM
bosch 68 442
Apr 23, 2011 07:26 PM
