Torque specs for header bolts??
Old Feb 17, 2012 | 03:11 PM
724drcutlass's Avatar
Question Torque specs for header bolts??
I was wondering what to torque the header bolts to after I take them off to paint. Also do I need to retorque after driving? 72 350 eng. Thanks for any info.
Old Feb 17, 2012 | 03:50 PM
380 Racer's Avatar
I guess I have never actually torqued a header bolt. I use a longer 7/16 box end wrench if possible. Sometimes you have to use an open end to get on some. The bolt threads are 3/8, so with an iron head will be tough to break or strip one. Oh ya I tighten from middle out with about 3-4 passes to keep things even, with fewer leaks. Use a good gasket. Recheck a couple times after good warm-ups.
PS. if you have trouble with gaskets leaking at the bottom of the flange.......leave the center bolt out.
Old Feb 17, 2012 | 04:03 PM
Great thanks! Should I replace the gasket if it has less than 1000 miles on it? Also what about using some hi temp sealer with the gasket?
Old Feb 17, 2012 | 06:01 PM
Rickman48's Avatar
I've found, over the years, the copper gaskets will last years, if tightened as above, [inside out] and once again, while hot!
Oven gloves help!
Old Feb 17, 2012 | 07:26 PM
380 Racer's Avatar
I personally have never used a sealer, but know guys who have and it did work for them. I like the Mr. Gasket HD gaskets and Fel Pro. I would do it now, it's easy rather than take them back off to replace the gaskets.
nolabigdawg
Oct 25, 2014 11:50 AM
Kidcutty
Jun 9, 2011 03:00 AM
dynamic88
Mar 7, 2008 03:32 PM
neoinbiz
Oct 24, 2006 07:42 AM
mcutlass1969
Jul 4, 2006 10:20 AM
