Toro vacuum hose routing
Old October 27th, 2017 | 01:35 PM
edzolz's Avatar
I searched the Toro section for a vacuum hose routing diagram and none popped up. Anybody have a pic they can send or post? A buddy bought a 69 and we are not sure the hose connections are correct. I also searched Wild About Cars site but did not find anything.
Old October 27th, 2017 | 06:48 PM
2blu442's Avatar
Are you looking for help with vacuum lines related to the carb, or the spaghetti for the headlights and other vacuum options?
Old October 27th, 2017 | 08:33 PM
edzolz's Avatar
Carb plumbing. Found a schematic on the net, but it shows an air pump and EGR. This 69 never had an air pump nor an EGR.
Old October 28th, 2017 | 05:56 AM
jaunty75's Avatar
What did you look for when you were on that site? You're not going find something like this by going to that site and simply typing "1969 vacuum hose routing" or something like that into the search box. You have to go to the service manual section and look at the appropriate section of the 1969 Chassis Service Manual. It turns out that there are seven separate figures over three pages in section 6 showing the vacuum hose routings for the different engine and carbs available. I think you have to actually join the site to be able to access these manuals.
I saved you the trouble this time as I've clipped out the three relevant pages and attached them here.
Old October 28th, 2017 | 06:45 AM
edzolz's Avatar
Thanks, I have a membership to their site but like you said, all I put in was the search words. I do appreciate the clip and next time I will change my search. I guess after 73 years I should know better.
dsolomon
June 1st, 2014 10:19 AM
RandyS
November 11th, 2013 03:05 PM
hurst72
Hurst/Olds
January 6th, 2013 11:18 AM
thomaswatk
February 10th, 2012 11:19 AM
skyjet olds
Ninety-Eight
July 27th, 2011 11:27 PM
Quick Reply: Toro vacuum hose routing
