Tires request
Tires request
I finally got 15x7 wheels, i talked it over with a good friend and decided to put 275/60r15 on it at the rear I'm going to keep the 235/60r14 up front. Right now I'm short on cash for the tires so its going to be a little bit, if anyone has a '72 or '71 or close to that Cutlass with similar tires on could you guys take a few snap shots and post so I can get a decent point of view? Please and thank you.
I don't believe you will have enough width in your rim size to support the 275/60R15 tires. Ideally the rims should be 7.5-9.5 in width. I think you would be better off with 8" rim width. Your tires are going to bulge out from the rim bead. IMHO
Nufo(Fred)
Nufo(Fred)
Also, the 275/60R15 is a 28" diameter tire, while the 235/60R14 is only 25.1" diameter. That's a 3" difference and will give the car a noticable rake. If that's what you're looking for, fine. But it might look a little hillbilly.....
Here is a website that I find very helpful when trying to decide which size tires to buy.......... http://www.tacomaworld.com/forum/tir...0r15-295-50r15
7" rim go 255/60/ on rear and use the 235 on front. My car in the signature 255/60/15 on rear and 245/60 up front. I think on your 71-72 you have a little more clearance to work with than the 68.
oldsguybry
Wheels and Tires
19
Feb 16, 2013 09:14 PM
