Timing settings
Old Dec 13, 2017 | 08:44 PM
woodie582's Avatar
Timing settings
Hi all,
I have a mild built 350 that was not running vac advance. I swapped out the original distributor with a pertronix billet intending to run manifold advance. This is where it’s at: initial is 12
32 with can hooked up
50 all in around 3200rpm.
4 speed, 3.23 gears. Starts quick when hot. Pertronix told me the can would add 14, wrong. My concern is the 32; haven’t driven it yet.
Old Dec 14, 2017 | 08:12 AM
Originally Posted by woodie582
Hi all,
What does "32 with can hooked up" and "50 all in around 3200rpm" mean? Do you have the vacuum advance connected for those numbers? If so, disconnect it and set the total to 34-36. Then connect the vacuum advance can.
Old Dec 14, 2017 | 08:23 AM
woodie582's Avatar
32 at idle with advance hooked up
50 @ 3200 rpm total with advance hooked up.
If I go for 34-36 I end up with 64-66 total @ 3200 rpm
The advance unit is putting in 20 degrees.
Old Dec 14, 2017 | 08:48 AM
You need to limit your vacuum advance with something like this if you want to go to 34/36. They are available through, Summit, Jeggs, Amazon, ebay, etc...
Old Dec 14, 2017 | 10:25 AM
woodie582's Avatar
Thanks Eric thats what I was looking at. I also have a dyno set up in January so I may just let them do the final set-up.
Old Dec 14, 2017 | 11:44 AM
Set your total (initial + mechanical) to 34-36 with the vacuum disconnected.
From there you have several options:
- Run it with the vacuum advance disconnected
- Connect vacuum advance to a ported source so it doesn't add to the idle timing
- Get a different vacuum can with less advance
- Buy and install the limiter posted above
- Make your own limiter as shown below
https://classicoldsmobile.com/forums...ck-timing.html
I made a limiter using a small bushing similar to the pic below. The advance canister originally gave 24º advance and the bushing cut that down to 16º.
I later made one out of a small piece of metal similar to the pic below and it is adjustable, so I now have it set to 10º.
Slash
Sep 29, 2016 05:06 AM
bainer1290
May 27, 2015 08:46 PM
Fastback71
Jul 7, 2012 09:42 AM
joepenoso
Apr 17, 2012 10:00 AM
