timing confusion
timing confusion
I am a bit confused about what is going on with the timing on one of my cars. It is a 1970 Cutlass with 350 2bbl. I have owned this car for aprox 2 years but have not driven it very much. It was bought as a 78K mile car and I believe it to be. I had to replace the vacuum advance, so while I had the distributor out I removed the points and installed a pertronix module. I did not check the timing before I removed the distributor. Here is where the confusion starts.
When the engine is rotated to align the TDC mark on the harmonic balancer and 0 on the timing indicator the #1 pistion is not at TDC.
I then rotated engine till the #1 piston was actually at TDC, installed distributor and engine fired up immediately and ran smooth.
The mark on the harmonic balancer is now at approx 10 o'clock position instead of 2 o'clock position by timing indicator.
I thought it had jumped time, but if that was the case it would not run smooth would it?
Any help is appreciated.
Don W
Don W
Yep, my balancer slipped on my 70 Vista also. When I changed the timing chain I verified it. I also checked a extra balancer and the one on my 71- they were both ok but the original on the vista had slipped. I replaced it with the spare and now all is ok.
I think you are right Pat. Talked to someone after posting and that is what they suggested. I am going to compare the harmonic balancer with others that I have. Will see how the timing mark/crankshaft key are located and compare.
When I put a timing light on it, the 0 mark on the balancer is at 10 o'clock position. The engine runs good.
Don W
Don W
Greg Rogers
Still interested in any parts you may replace on your Vista. Your Vista and my conv. have build dates that are very close. Just keep me in mind.
I have some Vista parts if you need to do some trading.
Don W
Don W
I bought another 70 Vista for parts that make David's old car look like a beauty, but it didn't have a engine. I don't know the build date of this one, but I will check- should be able to tell by the VIN? I'll keep you in mind Don.
In addition to a balancer shift you might want to also take a vacuum gauge reading AND go through the carb adjustments as well. Simple things like a vacuum leak, idle mixture settings, idle speed and having the vacuum advance on the wrong port can make your timing mark seem screwy. A vacuum gauge reading will help rule out other possible issues too.
Chris
Chris
