tilt wheel column
Old May 25, 2011 | 02:44 PM
charlierogers's Avatar
tilt wheel column
ok i got a good one for you experts out there. just recieved via ups a used floorshift tilt column for a 70 442. after opening box and packing i noticed 5-6 b.b size bearings on the floor?????? tilt mech seems to work right. where could these have come from???????????
Old May 25, 2011 | 02:51 PM
ok to answer my own question after looking at column it is the upper bearing. now where do i get new bearing? also would like to replace turn signal mech+ the steering harness. can i get these from napa or?? thanks for any help..
Old May 25, 2011 | 02:56 PM
my72vert's Avatar
In the tilt housing theres a top and bottom ball bearing that supports the steering shaft. They have plastic cages and are pretty delicate. Just my guess.
Old May 25, 2011 | 05:50 PM
stevengerard's Avatar
try rockauto for the turn signal cam
Old May 25, 2011 | 09:36 PM
70Post's Avatar
Contact this guy:
http://columnsgalore.com/index.htm
Should have everything you need
starfire
Dec 9, 2021 08:21 PM
Rocketbrian
Oct 2, 2013 10:18 AM
Bitburger
Dec 30, 2012 04:49 PM
ELECMAN
Jan 22, 2012 01:49 PM
ros6872
Feb 24, 2010 05:50 PM
