THH 350 Trans cooler lines
Old Oct 23, 2021 | 11:37 AM
ragtopblue's Avatar
Exclamation THH 350 Trans cooler lines
Well folks,
Seems my "In Line Tube" stainless steel trans cooler lines aren't as great as thought. The lower line corroded and sprung a leak ! I thought the reason for using stainless steel is because they didn't corrode or pit. So now I will be replacing them again. I need some people to weigh in and tell me what you used on your cars keeping it period correct. So hard lines will be used again. Lines were installed about 6 years ago.
Thanks Guys !
Old Oct 23, 2021 | 12:04 PM
70W-32's Avatar
Try Right Stuff Detailing or Classic Tube. I have Right Stuff brake lines and fuel lines on my car, no problems
Old Oct 25, 2021 | 02:01 PM
ragtopblue's Avatar
Never thought this would be as much as a pain as it is ! Right Stuff Detail doesn't carry a Trans cooler line set for a 71/72 TH350/TH400. Classic tube does but it is 6/8 weeks out ! Inline tube carries both steel and Stainless steel. But it was their product that corroded and developed the leak ! Now here it this question. My Cutlass Supreme has an OCT 1971 build date but is a 72 Model. I would assume that I would need the line set for a 71 TH350 not a 72. But the rep at Inline tube said that I would need to order the set for a 72 based on the model year. There is a difference between the two years. What is the groups feeling about this? Should I order lines for a 71 or a 72 ?
Old Oct 25, 2021 | 02:16 PM
4speed455's Avatar
The difference between the 71 and earlier and the 72 is where the top line connects to the radiator. The 72 has the upper line much lower then then the earlier ones. The 70 lines had a much longer drop in the upper line. I used 72 lines on my 70 because I bought them not not knowing the difference. It worked out for me because it kept the lines off my headers.
Old Oct 25, 2021 | 02:31 PM
70W-32's Avatar
Summit and Jegs both show Right Stuff cooler lines in stock
Old Oct 25, 2021 | 02:54 PM
442Harv's Avatar
Are you sure the ones they sent were stainless,and not miss marked?
Old Oct 25, 2021 | 03:07 PM
VC455's Avatar
Barely Registered
That would be unusual, even for a steel line, assuming you don't continually drive in winter salt.
Inspect the leak location carefully to see if it is from a crack or wear. You want to be sure you don't get a repeat of the problem.
Stainless can crack from repeated flexing. Steel not so much.
Stevec
Jun 27, 2012 05:12 PM
Mark71
Sep 19, 2011 02:32 PM
KZ442
May 29, 2011 04:58 AM
devmar07
May 14, 2010 09:23 AM
68conv455
Jan 3, 2009 11:53 AM
