Testing pick up coil and capacitor?
Old June 23rd, 2017 | 09:02 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
I have an almost new aftermarket capacitor in this distributor. I thought I toasted the Ignitor 3 module, replaced it with a new AC Delco module. It just happened to be the cheapest in stock but still too much. Either way the car cranks but is not firing. I assume a resistance check on both?
Old June 24th, 2017 | 03:13 AM
I don't understand the "replaced the igniter iii module with an ac delco module".
Old June 24th, 2017 | 05:06 AM
I don't understand the presence of both a pick-up coil and a capacitor.
Old June 24th, 2017 | 05:43 AM
HEIs have a radio noise suppression capacitor.
I ***-U-ME this is what we're talking about, though it might have been helpful to tell us what distributor this is...
Old June 24th, 2017 | 06:32 AM
Yes a GM HEI. Yes the suppression capacitor, which basically affects radio noise only, from what I read. If the pick up coil is toast, a cheap Chinese distributor with replace it since I want to try and sell my 88. I found the pick up coil tests online and how to test the coil. I will also make sure 12 volts is sitting where it should be as well.
Old June 24th, 2017 | 07:50 AM
No blink while cranking on the tach terminal. I bet the pick up coil is toast. I have only had one HEI module fail, didn't put the heat sink compound under it. I have seen multiple pick up coils fail.
bigin1978
January 27th, 2016 05:57 PM
QIK59
April 15th, 2014 01:41 PM
69'442
February 9th, 2012 10:11 AM
fjross
October 6th, 2009 06:43 PM
fjross
October 6th, 2009 04:59 AM
Quick Reply: Testing pick up coil and capacitor?
